Marantz SR7300OSE
Terrax
Looking to sell one Marantz Receiver, model number SR7300OSE
I don't have the original box, but do that the Manual and Remote. The receiver is 8/10 of the Audiogon scale.
Price $400.00 + Shipping.
To ship, I would double box and provide excellent packing.
Thanks for looking.
terrax@wnclink.com
Specs for Marantz 7300OSE receiver:
http://www.marantz.com/hifi/america/main.html
SR7300ose
SUPERCHARGED VERSION OF THE SR7300
The Marantz SR7300ose, a supercharged version of the Marantz SR7300, is designed for exceptional high-end home theater performance that incorporates DTS ES-discrete 6.1-channel decoding for enhanced surround sound realism. The additional back surround channel decoded from DTS-6.1 encoded discs provides a more realistic surround sound environment by allowing smoother, 360-degree sound effects. For enhanced performance, the SR7300ose incorporates a copper plated chassis with double bottom plate, upgraded power supply, better shielding and wiring and gold plated input and output jacks. The Marantz SR7300ose also offers a selection of other useful surround modes, including Dolby Digital EX, DTS 5.1 decoding. Dolby Pro Logic II (Music and Movie) decoding, an HDCD decoder, as well as SRS Circle Surround II (6.1). The SR7300oses advanced DSP circuitry utilizes 24-bit, 192 kHz audio decoding and a leading edge Crystal DSP chip for superlative fidelty and resolution. The SR7300ose is software upgradeable and easily controlled via a RS232C terminal and includes a programmable learning remote control.
FEATURES
110 Watts x 6 (Into 8 Ohms)
All Discrete Amplifier Stages
192 kHz/24-bit D/A Converters For All Channels
Dolby Digital EX 6.1/5.1, DTS 6.1/5.1
DTS 96/24
Dolby Pro Logic II (Movie, Music)
6 Channel Stereo Mode
HDCD Decoder
Multi-room, Multi-source Capability
Speaker A/B Switching
Gold Plated Inputs/Outputs
Copper Plated Chassis With Double Bottom Plate
Several modifications to the Power Supply, Signal Path, Output Devices, Preamp Stage as well as improved internal Wiring and Shielding
SUPERCHARGED VERSION OF THE SR7300 FEATURED
MULTICHANNEL/SURROUND
Software Upgradable (RS-232)
THX
DTS ES 6.1 Discrete/5.1/Neo:6 + DTS 96/24
Dolby Digital EX
Dolby Pro Logic II Yes
Circle Surround SRS CS 6.1
SOUND ENHANCEMENTS
HDCD Decoder
Current Feedback Topology
Discrete Amplification Yes
Power Transformer EI (Upgraded)
D/A Conversion 192 kHz/24-bit (Hand Selected)
Digital Surround Processing Crystal (Hand Selected)
Video Off
Source Direct
Chassis AllCopper w/ Double Bottom Plate
Customized Components
Shielding Extensive Shielding in all Critical Areas
IN/OUTPUTS
VIDEO
Composite In 5 (gold plated)
Composite Out 3 (gold plated)
S- Video In 5 (gold plated)
S- Video Out 3 (gold plated)
Component In 2 (gold plated)
Component Out 1 (gold plated)
AUDIO
Analog In 8 (gold plated)
Analog Out 4 (gold plated)
Digital In 7 Total
Digital Optical In 4 (3 assignable)
Digital Optical Out 1
Digital Coaxial In 3 (assignable)
Digital Coaxial Out 1
OTHER
Pre- Amplifier Out 7.1 Channels (gold plated)
Main Amplifier In
Multi-Channel In 8 Channels (gold plated)
Multi-Room Audio Out L/R Pre-out (fixed or variable)
Multi-Room Video Out 1 (CVBS)
RS232C
DC Triggers 2 (assignable)
Speaker Terminal A/B + C, Sl, Sr, Sb
Multi-Room Speaker Terminal
D-Bus RMC Out Yes
Multi-Room RMC Yes
External IR Yes - thru RC-5
AC Outlets Yes, (1 switched/1 unswitched)
Front Inputs L/R, CVBS, S, Opt. Digital
Headphone Out
SPECIFICATIONS
AUDIO SECTION
Power Output (8 Ohm) 110 W x 6, (<0.08% THD, 20Hz - 20 kHz), SA-Ready
Signal to Noise Greater than 105 dB
Freq. Response (Analog In) 8 Hz - 100 kHz
Freq. Response (Dig In) 8 Hz - 45 kHz
Input Sensitivity 195 mV/47k Ohms
TUNER SECTION FM
Frequency Range 87.5 - 108.0 MHz
S/N Ratio (Mono/Stereo) 70 dB/75 dB
Distortion (Mono/Stereo) 0.3%/0.2%
Channel Selectivity
Usable Sensitivity IHF 1.8µV/16.4 dBf
Channel Separation Greater than 45dB (1 kHz)
TUNER SECTION AM
Frequency Range 531 - 1710 kHz
S/N Ratio 50 dB
Distortion 0.5%(1 kHz)
Channel Selectivity
GENERAL
Color Black
Front Panel Aluminum
Remote Control Learning with LCD - RC7300SR
Power Requirement AC 120v / 60Hz
Dimensions Inch W x H x D 17 5/16 x 6 3/8" 18 1/4"
Weight 35.1
Thanks for looking.
terrax@wnclink.com
SR7300ose
FEATURES
DTS 96/24
HDCD Decoder
THX
Dolby Digital EX
SOUND ENHANCEMENTS
HDCD Decoder
Video Off
Source Direct
IN/OUTPUTS
VIDEO
AUDIO
Digital In 7 Total
OTHER
Main Amplifier In
RS232C
D-Bus RMC Out Yes
Multi-Room RMC Yes
Headphone Out
SPECIFICATIONS
AUDIO SECTION
TUNER SECTION FM
Channel Selectivity
TUNER SECTION AM
S/N Ratio 50 dB
Channel Selectivity
GENERAL
Color Black
Weight 35.1
Post edited by Terrax on
This is a great receiver for home theater, and is very musical as well.
Edit: *Sale Pending*
*Bump*
Sounds like a really nice machine, I'd be interested for sure if I was in the market. Good luck.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie
