Polk Audio Monitor 5B Crossover Modification Thread
VR3
VR3 Posts: 29,535
edited May 2014 in DIY, Mods & Tweaks
This is a "first", a "Fortress" round plate series - tricky way to mount it for sure!
Post edited by VR3 on
  • zane77
    zane77 Posts: 1,696
    edited November 2013
    Very nice, did you glue the inductor to the back of the terminal plate?
    Two Channel
    VR3 Posts: 29,535
    Thank you! :)
    Nope...
    We mounted the old terminal on the inside, threaded rod to the outside and attached the aluminum plate via acorn nuts...
  • FTGV
    FTGV Posts: 3,650
    Nice aluminum plate.Do you by chance have square alum plates that would fit the standard plastic dual terminal plate opening(ie LSi 9)?
    VR3 Posts: 29,535
    Yes sir - here they are for a LSi9 modification
    Thank you! :)
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited May 2014
    have you done any 5JR+? curious about what mods are available and costs, i know little to none about what actually goes into modding them, i do want new caps and modern terminations though, cardas ccrr is what im leaning towards. new wiring is a thought as well. i havent heard them yet, found a good deal and had my dad grab em for me. i can email you if you would like, and we ca discuss different options, orif you have different mod "packages" available already, i would love to know what they are.
  • seabeerob213
    edited May 2014
    side note, i know 5B's are not the 5JR or JR+, just figured this was the most relevant thread to post in
