SQB Controller question...
steveinaz
steveinaz Posts: 19,545
edited November 2013 in Going Digital
My Squeezebox controller shows the wrong time, it's an hour behind. My computer and SQB Touch both display the correct time. The only "time" settings I see on the controller are time format, but nowhere to set the time.
Help?
Post edited by steveinaz on
  • recoveryone
    recoveryone Posts: 929
    Just wait until next spring and it will work out fine LOL...... had to get that in.
    sounds like a reset is in order
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    I was gonna suggest you just move a few hundred miles to the east or west and that should resolve your time zone issue...
  • steveinaz
    I'm thinking maybe I need to add it as a device on mysqueezebox.com, then maybe it will sync up properly? Already did a reset--it's still behind an hour.
    An Old Indian once said, "Only the government would believe that you could cut a foot off the top of a blanket, sew it to the bottom, and have a longer blanket."
  • zane77
    zane77 Posts: 1,696
    Isn't Arizona the only place that doesn't practice Dalight Savings Time? Sounds like a move is in order.
    Two Channel
  • steveinaz
    Found the solution:
    Settings>Advanced>Drill waaaaaaaaaaaay down to "Time Zone." Now, why wouldn't they have the time zone setting with the Date/Time settings?
