SQB Controller question...
steveinaz
My Squeezebox controller shows the wrong time, it's an hour behind. My computer and SQB Touch both display the correct time. The only "time" settings I see on the controller are time format, but nowhere to set the time.
Help?
Help?
Post edited by steveinaz on
Just wait until next spring and it will work out fine LOL...... had to get that in.
sounds like a reset is in orderFamily Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX -
I was gonna suggest you just move a few hundred miles to the east or west and that should resolve your time zone issue...
I'm thinking maybe I need to add it as a device on mysqueezebox.com, then maybe it will sync up properly? Already did a reset--it's still behind an hour.
An Old Indian once said, "Only the government would believe that you could cut a foot off the top of a blanket, sew it to the bottom, and have a longer blanket."Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Isn't Arizona the only place that doesn't practice Dalight Savings Time? Sounds like a move is in order.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Found the solution:
Settings>Advanced>Drill waaaaaaaaaaaay down to "Time Zone." Now, why wouldn't they have the time zone setting with the Date/Time settings?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
