Doobie Brothers : The Captain and Me CD
muncybob
As usual there are many CD versions and of course some are better than others. I've read to stay away from the Warner Brothers versions. On EBay there are some MoFi and Japan imports. Some imports are what I would expect to see priced at over $30 or so but there are some that are a lot cheaper. Are there any issues out there for say under $30 that are worth picking up?
Yep, my name really is Bob.
Post edited by muncybob on
CD only or can it be SACD?
If so, the MoFi SACD is *really good*.
Ditto re the Mofi SACD's. All of the Doobies ones are excellent. I haven't played the CD layers though.Parasound P5 Pre
Marantz AV 7703 Pre/Pro
Outlaw 7500 Amp
Marantz SA14s1 SACD/CD
Rega Planar 2 TT
Polk Audio Speakers: LSiM 705 Fronts, LC65FX Surround, LSiM 704c
Oppo BDP-103 -
buying one today to go with my DVD-Audio of the same "Captain and me"
Is the MoFi SACD multi-channel...would rather 2 channel.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Parasound P5 Pre
Outlaw 7500 Amp
Rega Planar 2 TT
Oppo BDP-103 -
Erik Tracy wrote: »And perfect that way, too! :cheesygrin:
Exactly - live bands don't play in surround sound.
Parasound P5 Pre
Outlaw 7500 Amp
Rega Planar 2 TT
Oppo BDP-103 -
Anybody know anything about Ninja Records???
Saw this: DOOBIE BROTHERS The Captain And Me WPCR-2653 JAPAN CD l879Yep, my name really is Bob.
