KnuKonceptz Karma
Geoff4rfc
Geoff4rfc Posts: 2,837
Has anyone used or using this cable? As far as the 10awg goes, it looks like a pretty decent product and not too badly priced.
http://www.knukonceptz.com/productDetail.cfm?prodID=KAR10SS-100
Set up:
Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
Post edited by Geoff4rfc on
  • Geoff4rfc
    edited November 2013
    Oh yeah, I forgot to ask......and if those that have used and are using, would you recommend this product?
    Set up:
  • Jimbo18
    Jimbo18 Posts: 2,349
    Geoff4rfc wrote: »
    I haven't used that specific cable but I am using KnuKonceptz 14ga. I was skeptical that I would hear a difference over the old 16 ga. wire I was using. Mainly due to my old ears and lack of experience, but it definitely opened up the soundstage. I never had very good high freq. hearing, so can't say about the highs, but the mids and lows are more defined than before.
    But that's just comparing it to cheap wire, can't say how it would be compared to higher quality/price cable, but I am happy with it. I don't much care for their nanners though.
    Check out the Ethereal 14 ga. wire here at AC4L, it looks and reads exactly like the KnuK that I have.
    http://www.accessories4less.com/make-a-store/category/SpeakerWirePins/Speaker-Wire-Connectors/1.html
  • zingo
    zingo Posts: 11,258
    For budget 10AWG wire, I recommend Blue Jean Cable Ten White.
    http://www.bluejeanscable.com/store/speaker/
