Amps Suggestion for the setup below. Kindly Help. URGENT
dheep4225
I'm looking to get advice on what the best amp or amps would be for the setup below in my Ford Figo Hatchback.
JVC KW AV50 DVD/CD/USB Receiver or Sony XAV 601BT
Polk Audio MM6501 in front.
Polk Audio MM691 in the rear.
Polk Audio DB1212 12'' Subwoofer Enclosure.
I'm into classic rock, death metal and hard rock... So I'm looking for sound quality with punchy, accurate, and clear bass, mids, and highs. I don't listen ridiculously loud most of the time, but I would like that capability... and I definitely want clean sound.
Can I use Polk Audio MM6501 both in front and rear?
Thank You.
Thank You.
Post edited by dheep4225 on
There is nothing urgent about this... sheeshMain Surround -
