jumpers on terminals w/ SDA
leftwinger57
leftwinger57 Posts: 2,917
edited November 2013 in Electronics
A few threads ago there was a great picture of the rear terminal cup of a SDA speaker showing top red and black binding posts and bottom binding posts and there was a jumper from red to red and black to black and the i/c cable was being used.If the jumpers are not used would this be an application for bi-wiring or is there some other function for these jumpers.Newer speakers like Vandersteens in particular not only suggest it Richard Vandersteen himself claims it's a must do, to get the full potential of his 2ce Sigs and 3As. This bothered me because inaddition to using an expensive biwire set up he also insists on using the Anchor stands to get the tweeters to line up to your listening level.If such a genious and inventive guy why is all this other stuff needed on brand new speakers.
Yes he did answer the phone and we spoke for a little, no I didn't grill him on these questions I didn't know of them at the time. This was when I was looking at a set of used Walnut 2ce at 1 of his Jersey sellers and he knows by name all his distributors.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    A lot of guys on the forum can give you much more technical information, but for now, I can say that the jumpers are necessary if you do not bi-wire or bi-amp your speakers. The upper posts serve the upper frequency network and the lower posts serve the lower frequency network. If you do not connect the jumpers and your speaker cables are not connected to both sets of posts, you won't get signal to one network or the other.
    tonyb Posts: 33,072
    Moose has it down.....seriously though LW, jumpers are on most any speaker these days. You remove them if you want to bi-wire/bi-amp, or leave them in place for single speaker wire. Or change them out for better, but the principle is as Moose explained.
  • leftwinger57
    That's fine, and yes these days you see jumpers on even fairly small bookenders besides all kinds of brands .I was right but these were on an earlier design so I didn't think that seperateing the highs and lows were done back then.I can't imagine how w/ a good bi-wire and using the i/c cable how those speakers would sound.
    tonyb Posts: 33,072
    The bi-wire isn't as relevant as the I/c cable on SDA's. Don't fret over bi-wiring, fret over getting the I/c cable.
  • leftwinger57
    Tony, I'n not frtetting over anything . My 2bs can't be bi wired and i wouldn't do anyway and I have the cable.I was just asking about those particular speaker cups on someone else's speakers.
