phono pre amp recommendations needed
pglbook
pglbook Posts: 2,262
edited November 2013 in Electronics
I am looking for suggestions on what would be an excellent phono pre amp to match with a Parasound P/LD 1500 pre amp and a Parasound 1500A power amp. This is for a strictly 2-channel system for my Polk SDA 2B TL speakers and Rotel RCC 1055 CD player.
I just purchased the Parasound P/LD 1500 pre amp from a fellow PF member yesterday and will get it next week. I had been looking for a pre amp with a phone stage but I heard great things about the Parasound P/LD pre amps and decided to get the P/LD 1500 pre although it doesn't have a phono stage. So now I will need to get a separate phono pre amp.
I like to spin vinyl at least a few days a week so I would like to get an excellent phono pre amp. My budget is around $200 - $300 so please let me know if there are some good phono pre amps that would be within my budget. I think vintage is the way to go to maximize quality and cost.
I'd appreciate suggestions on what phono pre would be a good match for my Parasound pre and power amp and also would be within my budget.
Thanks.
Post edited by pglbook on
  • brgman
    brgman Posts: 2,859
    edited October 2013
    Might as well look at the Parasound ZPhono if you haven't
    For the money I've read it's pretty good.
    For vintage at that dollar level I haven't any idea what you can find.
    Just watch the audio boards.
    I’M OFFENDED!!!!
    EndersShadow Posts: 17,705
    edited October 2013
  • hochpt21
    hochpt21 Posts: 5,423
    edited October 2013
    Congrats on eight grand Enders.
    edited October 2013
    hochpt21 wrote: »
    Huh????
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited October 2013
    ^ your post #, wake up
  • pglbook
    edited October 2013
    Thanks for the recommendations, brgman and EndersShadow.
    Does anyone have any experience with the Music Hall PA 1.2 phono pre amp? I have been doing some online research on phono pre amps and that one also gets good reviews.
    Thanks again.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited October 2013
    I've got a first generation stock Jolida JD9 if you want to consider that.....
  • pglbook
    edited October 2013
    Thanks, Erik. The Jolida JD9 seems like a great unit but it would be beyond my budget (under $300).
  • Erik Tracy
    edited October 2013
    pglbook wrote: »
    Check your PM....
  • mrbiron
    mrbiron Posts: 5,721
    edited October 2013
    Bugle- $139
    If mine ever shows, I could let you know how it sounds.
    SCompRacer Posts: 9,112
    edited October 2013
    pglbook wrote: »
    Thanks again.
    My friend Rob has one. He was looking to upgrade from his Pro-Ject 2.9 table. He always lusted over my Nottingham Space 294 and the time came I was selling it. I took it over there, the idea being only if he heard an improvement that he should buy it. We first installed his Sumiko Blue Point cartridge on the Space for a more apples to apples comparison and then my Karat 17D3. I was not expecting much but the PA 1.2 clearly showed the improvements a better table and then a better cartridge can make. I was really impressed.
    The PA 1.2 has a fixed MC loading of 100 Ohms so you have to match a cartridge to it. Higher priced offerings will allow for different MC loading settings. MM is standard 47k Ohm loading.
  • pglbook
    edited October 2013
    Thanks mrbiron and SCompRacer.
    I am still researching phono pre amps so the info is much appreciated.
  • nspindel
    nspindel Posts: 5,343
    edited October 2013
    You can get the Belari cheaper than that from Amazon:
    http://www.amazon.com/Bellari-VP130-Preamplifier-Headphone-Amplifier/dp/B002TD4GME
    One criticism of it that I've read is that it can use a power supply upgrade, but with a better power supply it's supposed to be really great.
  • vcwatkins
    vcwatkins Posts: 1,993
    edited October 2013
    Re: Bellari, I can't speak to VP130 per se, but I've used the 530 to rip vinyl and listen to records in my study. I really like it for that purpose, but am waiting to see if something like the new PS Audio unit would be worth the the $. There's no power switch on the Bellari - a little weird - and I can easily imagine a better power supply would benefit it. With a NOS Mullard, it's detailed and smooth with adjustable gain. I would imagine the 130 is similar in performance minus the ADC. I do see 530's going at a discount occasionally. I paid $350 at Amazon.
    I was happy with a Project Tube Box II ($280 used) which I thought was noticeably better than the Phono Box II ($100 used). I ended up replacing the Tube Box with a JD9ii. Haven't modded, but love it still.
    Craig
  • george daniel
    george daniel Posts: 12,096
    edited October 2013
    Check out the used Dynavector P-75
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2013
    Also look at needle doctor, audio advisor, MusicDirect, etc, etc for "demo" or "open box" deals on better pres. I picked up a new Sim Audio Moon pre for almost 1/2 retail some years ago. I think it retailed for $525, and I got it for $275.
  • pglbook
    Thanks for all of the input.
    I have been researching a lot of the suggestions, as well as other phono pre amps, and I am now leaning towards getting the Clearaudio Nano phono pre amp. It gets great reviews.
    Does anyone have any experience with it?
  • 4xoddic
    4xoddic Posts: 372
    The Rogue Audio Stealth/Magnum was replaced recently by the Triton. A Magnum sold on ebay recently for $425 (incl ship). I got a Stealth for ~ $368 (incl ship) this year. American made, Rogue Audio still has the parts to upgrade to Magnum level.
    I spoke with Jim Pendleton, owner of Osage Audio, when I was pursuing a CA Nano (evidently replaced by Clearaudio Nano V2). He mentioned a couple of other brands @ that price point he thought were better suited for my TT; but did say the Nano sounded better than CA's next higher model.
