Mounting Blackstone speakers on the wall
mdaudioguy
For anyone who has Blackstone speakers, have you wall-mounted them? I'm wondering if there's room to wall-mount TL3 front sats and center, and use banana plugs, or would bananas stick out too far? The TL3 manual mentions that a bracket is included, but I can't find a picture of said bracket.
Post edited by mdaudioguy on
http://www.monoprice.com/Product?c_id=108&cp_id=10828&cs_id=1082804&p_id=8284&seq=1&format=2
I ended up using these brackets, and yes you have room for the smaller bananas2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »http://www.monoprice.com/Product?c_id=108&cp_id=10828&cs_id=1082804&p_id=8284&seq=1&format=2
I'm using those brackets for the surrounds. Smaller bananas? -
Since I really want a flush wall mount in the front, I guess I'll have to go spades or bare. Thanks guys!
