RTA 11t issue
canitdive
canitdive Posts: 5
edited October 2013 in Speakers
Just picked up a pair of RTA 11 t and noticed that the one speakers top driver is pounding away and yet on the other speaker it is not. I swapped the upper driver with the lower driver in the cabinet and it seems to match the other speaker.?
Also i noticed that on the other speaker that the top driver had an issue with a scratchy voice coil so they guy i just got them off had some spare Polk 61/2 drivers and gave me one, I noticed right away after i replaced the driver that the lower bass output from this speaker increase. So im guessing i have to replace all 4 6 1/2 driver and upgrade the crossover
I am using a Onkyo 9.2 receiver to power them and even with all there issues I am happy with them. paid $150 Canadian.
Any advise on where i should start?
Cheers
Andrew
Post edited by canitdive on
  • Nightfall
    Nightfall Posts: 10,084
    edited October 2013
    Your post is a little confusing. Do you have any MW's left that are frozen or scratch when the driver is gently pushed in? If not I wouldn't bother replacing them.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • canitdive
    canitdive Posts: 5
    edited October 2013
    All the other drivers seem to be fine no scratchy voice coils. but on the other speaker with the new driver i just installed seems to move both lower PR alot more than the other speaker! Crossover issue maybe?
    cheers
    Andrew
    F1nut Posts: 51,674
    edited October 2013
    Tell us what model number is printed on the back of each driver. It will start with MW followed by 4 numbers.
  • canitdive
    canitdive Posts: 5
    edited October 2013
    The number on the back of the speaker with the bad voice coil is MW 6510. Are there replacements available ?
    Cheers
    Andrew
    F1nut Posts: 51,674
    edited October 2013
    Ok, that is the correct driver. You should check that ALL the other drivers are MW6510's as well.
    Yes, Polk stocks that driver. It looks a little different than the originals and you'll have to cut a notch in the rubber surround where the screw holes are.
    F1nut Posts: 51,674
    edited October 2013
    Oh yeah, be sure to mention you are a Club Polk member to get your discount.
  • canitdive
    canitdive Posts: 5
    edited October 2013
    Will they ship to Canada?
    I also read that there is a crossover update and a tweeter replacement any advise on these issues.
    cheers
    Andrew
    F1nut Posts: 51,674
    edited October 2013
    I believe you have to order parts thru the Canadian distributor, but ask Polk first.
    There isn't a crossover update from Polk, there is a crossover upgrade that you can do yourself or have an audio shop do for you. IIRC, your speakers use the SL2000, so there is an upgrade to the RD0194-1. It's a vast improvement.
  • canitdive
    canitdive Posts: 5
    edited October 2013
    cool thankyou!
