LSI 25 Speaker issue
bdaley6509
Just picked up a pair of LSI 25's from a member here on trade and the left channel high end is muffled and not outputting correctly, specifically with the tweeter. I swapped a known good tweeter with the same results, and also switched channels on my amp output to make sure the problem didn't follow the amp channel. Needless to say, I'm not sure on next steps to resolve this. I assume the crossover, but does anyone have any experience/ideas or lend a hand? Thanks!
Post edited by bdaley6509 on
I know that you're looking for a simpler answer, but since you swapped the tweeter try swapping the crossover.
Could be a loose wire too, check the crossover and behind the binding posts. Check your connections also, you using banana's spades, bare wire ?HT SYSTEM-
lsi 9's -
Do these use the binding post jumpers? Check those.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
no...I have them bi-wired. Shout out to Polk customer service. They are sending me a replacement crossover.
Is that an RMB-1075 I see?Main Surround -
