Bookshelf speaker advice
Advice from you Polk aficionados. I was set on buying a some Boston Acoustics until I heard a pair of T300's. So here it goes.
Receiver is a Onkyo TX-SR507
T300 - $129
TSX110B - $139
RTiA1 - $219
Speakers are used for 95% movies.
I assume the RTiA1 sounds better. But, how much difference would I hear between the tsc110b and the rtia1?
Thanks for the advice!
T300 - $129
TSX110B - $139
RTiA1 - $219
Post edited by mllerens on
The RTi-A1 is the best choice! You will be very happy with the sound!Make it simple...Make it better!
I run some Rti-4s and a 100 watt 8" sub on an Onkyo TX-SR604 in my bedroom. They do a very very nice job for movies as that is the main function of that system.
Rti-4s are the older version of the Rti-A1s so here's another vote for those but with a SUB!
