Does this look right?
VR3
It will work --
Thanks for the fast responses as always.
Sure, if you are looking for less than optimal sound, it will work.
What a mess.
Cheers,
Please PM for suggestions to alternate methods.
Thank you for the fast responses.
- Sid The Kid- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Squid-ward, I mean Sid-ward, what is up with the speaker switch? Keep it simple young'in. All that crap in your signal path is negating the big-bucks you've spent for high-end equipment.
There's got to be a better solution than shown above. You are using the "line level" inputs on your SVS right?
Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Thanks for the responses.
If you wish to offer advice on an alternative method other than a speaker switcher --
Please PM me or E-Mail me with the idea.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
