Does this look right?
VR3
VR3 Posts: 29,426
It will work --
Thanks for the fast responses as always.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited June 2004
    Sure, if you are looking for less than optimal sound, it will work.
    What a mess.
    Cheers,
    Russ
    VR3 Posts: 29,426
    edited June 2004
    Please PM for suggestions to alternate methods.
    Thank you for the fast responses.
    - Sid The Kid
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2004
    Squid-ward, I mean Sid-ward, what is up with the speaker switch? Keep it simple young'in. All that crap in your signal path is negating the big-bucks you've spent for high-end equipment.
    There's got to be a better solution than shown above. You are using the "line level" inputs on your SVS right?
    VR3 Posts: 29,426
    edited June 2004
    Thanks for the responses.
    If you wish to offer advice on an alternative method other than a speaker switcher --
    Please PM me or E-Mail me with the idea.
