Weakest link in my setup?
kadrek
kadrek Posts: 33
So this is what I'm using for 2 channel listening now.
Laptop -> UCA202 usb dac -> Monoprice 10' RCA Component Coaxial Cable -> HK 3480 -> 14 gauge speaker wire from RadioShack -> Monitor 60's Series II.
What upgrades would provide the best bang for the buck? Thanks for any suggestions!
Post edited by kadrek on
    EndersShadow Posts: 17,715
    edited October 2013
    Agreed DAC first...
    But most important question... "How" are you listening out of your computer i.e. what is your source file format (MP3, FLAC, etc) as well as bitrate (96kb, 320kb, etc).
  • kadrek
    kadrek Posts: 33
    edited October 2013
    DSkip wrote: »
    HK and speakers would be last on the list for me. The HK isn't shabby and more revealing speakers might make your system actually sound worse. The Monitors are rather forgiving. I'd be looking at the DAC first, then IC/SC. How much is the buck?
    Around $100 if possible. I saw the $100 Schiit Modi Dac that seems to have good reviews.
  • kadrek
    kadrek Posts: 33
    edited October 2013
    Agreed DAC first...
    I mostly use Spotify Premium, 320kbps supposedly. I'd like to have more FLAC files but it just seems like a hassle, is there any easy way to get FLAC files?
    edited October 2013
    kadrek wrote: »
    Take your existing CD library and convert it to FLAC via dbpoweramp (30 day free trial) and then buy that program, or buy MediaMonkey which is both a library managment/playback program as well as a CD Ripper.
    Lots of threads on those two products so I wont talk more about them.
    Since your source files is of a good quality, DAC would be my next step. That said I dont know what your going to be able to get for 100, its probably going to have to be used to save a buck or two. Then USB & coaxial cable. I bought a Black Cat Veloco digital cable off this forum and it made a HUGE difference in my 2 channel setup*. For USB I would suggest picking up a Audioquest Forest in whatever length you need. Then speaker wire.
    * I am also using my computer as my source for FLAC files via XBMC, as well as MOG and at times Pandora.
  • BlueFox
    BlueFox Posts: 15,250
    edited October 2013
    kadrek wrote: »
    This is your weakest link. The best equipment in the world will not help butchered music.
  • kadrek
    kadrek Posts: 33
    edited October 2013
    Thanks for the suggestions guys.
