Speaker Isolation
Easy Runnin
I have a monitor 5 sitting on top of an armoire. The armoire is made out of thin wood? The speaker is causing the armoire to resonate at even moderate volumes. Besides moving the speaker and/or dynamatting the armoire, what's the best way to address this issue. I thought about putting rubber pads/feet on the bottom of the speaker but figured I would ask here first.
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
rubber feet will do it....or you can kick it up if need be:
These sorbothane disc are whats between the RT3000p top cabinet and bottom sub cabinet...there are other shapes and sizes avail on amazon:
http://www.amazon.com/Isolate-It-Sorbothane-Vibration-Isolation/dp/B00CQ4FU8U/ref=sr_1_1?ie=UTF8&qid=1379874916&sr=8-1&keywords=sorbothane+isolators+disc
Then there is something like this foam feet that you might find in a studio...they can be used to andle the speakers also:
http://www.amazon.com/Auralex-Monitor-Isolation-Speakers-Charcoal/dp/B0002D0B4K/ref=sr_1_1?ie=UTF8&qid=1379874837&sr=8-1&keywords=monitor+isolators2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
