How to get these storage marks off audio cd
Sumerian
As important what you use as a cleaner is what you wipe the cleaner off with. I highly recommend a "microfiber cloth" to wipe with.
That said, windex might work well. I have used it a on a couple cd's with no problems.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Get some optrix.
If that doesn't work you may have to use mapleshade polish.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Did you try a little isopropyl?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
If you have any DVD rental shops in town most have a DVD/CD cleaning machine they run their rentals through when the inconsiderates bring the dirty rentals back. The family video store up the street charges a couple of bucks. I have brought a few used cd purchases to them they look like new after being run through the machine.Home Theater
^^^^That would work well too.^^^^
That said, the Optrix and Mapleshade polish are more "treatments" than "cleaners". The Optrix might get the marks off however. I haven't used the product myself. I would try isopropyl and/or windex first however. And again wipe with a microfiber cloth.
Did these CD's get very warm while in the plastic wrap while in storage?
I am not sure but I guess so .. the plastic wrap was stuck to the cd -
Yeah, I had a feeling that was the case. I would try some isopropyl alcohol (91%) and see if that works. If not, you may have to go the buff them out route.
OK looks like i already have that CVS alcohol thingy .. which is actually isopropyl 91%.
strangely it worked good on the second CD shown in second pic above but the first one shows no effect
