How to get these storage marks off audio cd
Sumerian
Sumerian Posts: 490
edited September 2013 in Music & Movies
I have recently bought few NOS audio CD's ... unfortunately these are stored in a plastic wrap and it left some sort storage marks on the cd.
I tried cleaning of them with lite soap but it had actually made it worse.
Atleast i was able to rip other cd's with errors.
Post edited by Sumerian on
  • headrott
    headrott Posts: 5,496
    As important what you use as a cleaner is what you wipe the cleaner off with. I highly recommend a "microfiber cloth" to wipe with.
    That said, windex might work well. I have used it a on a couple cd's with no problems.
  • brgman
    brgman Posts: 2,859
    Get some optrix.
    If that doesn't work you may have to use mapleshade polish.
    I’M OFFENDED!!!!
  • brgman
    brgman Posts: 2,859
    Did you try a little isopropyl?
    I’M OFFENDED!!!!
  • Sumerian
    Sumerian Posts: 490
    brgman wrote: »
    I tried Lens cleaner that didn't work.
    gudnoyez Posts: 8,174
    If you have any DVD rental shops in town most have a DVD/CD cleaning machine they run their rentals through when the inconsiderates bring the dirty rentals back. The family video store up the street charges a couple of bucks. I have brought a few used cd purchases to them they look like new after being run through the machine.
  • headrott
    ^^^^That would work well too.^^^^
    That said, the Optrix and Mapleshade polish are more "treatments" than "cleaners". The Optrix might get the marks off however. I haven't used the product myself. I would try isopropyl and/or windex first however. And again wipe with a microfiber cloth.
  • headrott
    Did these CD's get very warm while in the plastic wrap while in storage?
  • Sumerian
    Sumerian Posts: 490
    headrott wrote: »
    I am not sure but I guess so .. the plastic wrap was stuck to the cd
  • headrott
    Sumerian wrote: »
    Yeah, I had a feeling that was the case. I would try some isopropyl alcohol (91%) and see if that works. If not, you may have to go the buff them out route.
  • Sumerian
    Sumerian Posts: 490
    OK looks like i already have that CVS alcohol thingy .. which is actually isopropyl 91%.
    strangely it worked good on the second CD shown in second pic above but the first one shows no effect
