Oppo-105 . . . What are the Cons? Are there any?
GlennDog
GlennDog Posts: 3,149
edited September 2013 in 2 Channel Audio
I'm about to pull the trigger. It will be used as a major improvement over the Adcom GCD-700. TWO channel nirvana, primarily.
All that I've read are excellent reviews, albeit with no negative feedback (there must be something lurking behind the scenes)
ANY NEGATIVES RE: THE 105?
TY
G
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
Post edited by GlennDog on
    Toolfan66 Posts: 17,992
    None from me..
    EndersShadow Posts: 17,687
    Yup.... cost :wink:.... and then buying more CD's and SACD's to spin :wink:
  • Conradicles
    Conradicles Posts: 6,331
    I personally feel it does not look like a high end player. Not bad at all, just not that sexy.
    However that is not a bad thing, just a thing.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    Out of the box the 105 can sound a little harsh, that's about the only negative and it disappears with burn in. At about 50 hours mine settled in, maybe minor improvements but at 50 hours you basically have the sound you're gonna get.
  • GlennDog
    GREAT INPUT SO FAR, THANK YOU!
    I'm going to take the plunge (along with some MIT cables i'll post about later)
    I was toying with the 105 ModWright mod, but not being able to audition the piece was out of the question (too costly). I am expecting HUGE improvements!!
    G
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • AsSiMiLaTeD
    I don't know much about the preamp you're using, but also try the 105 as a preamp if you can.
  • brgman
    brgman Posts: 2,859
    GlennDog wrote: »
    G
    Get the 105 and run it for about 3 months.After that if you go with a Modwright upgrade you will be better suited to hear all the difference.
    Pricey? Yes.
    Worth it?
    Hell Yes!
    I bought a second and drop shipped it and then had a nice A/B of the two for about a day.Then I never turned on the stock unit again.
    Oh and get ya some Sophia Electric 6sn7's for it.
    Enjoy
    I’M OFFENDED!!!!
  • WLDock
    WLDock Posts: 3,073
    brgman wrote: »
    Would like to hear the expensive upgrade...maybe someday.
    F1nut Posts: 51,689
    So, the stock version isn't all that.
  • brgman
    brgman Posts: 2,859
    Stock was great.But the for me the Modwright was far superior.Especially after i upgraded the tubes to the Sophia's.It's a pricey move but i always wanted a tube DAC and player and this was a home run for me.
    I’M OFFENDED!!!!
  • GlennDog
    I've got that on my radar!
    I've been using a Cary SLP-98 pre that may be going back to the factory for a HT by-pass and hexfred rectifier upgrades. That should take it to the next level!
    Dang, this rabbit hole sure is deep . . .
    G
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    txcoastal1 Posts: 13,500
    GlennDog wrote: »
    G
    You'll enjoy that Cary upgrade, don't be to judgmental till break in, but she''l sing like a bird
    pitdogg2 Posts: 26,956
    ^^^^^^ding ding ding but then again I wouldn't necessarily think that would be a con.
    tonyb Posts: 33,067
    The oppo is a great product at a great price point. Offers up a lot for that price too. The only Con I can think of is getting up to change CD's. :wink:
  • AsSiMiLaTeD
    I spent some time with the headphone section today, and it is actually surprisingly good. It's not super powerful, but drives the HE-500 and HD600 very well on about 98% of the music I listen to. Only a handful of really quiet recordings like Patricia Barber's Cafe Blue and Chris Isaac's Heart Shaped World need a little more juice with these cans than this amp can provide. Those albums still sound great, but could use an extra 3db or so just to provide that last bit of impact to the sound.
  • sk88
    sk88 Posts: 159
    Can I assume that you all use the 2-channel analog out on Oppo (not HDMI, to get the sound quality)?
    p.s. I dont' own a Oppo so I don't know.
    • Online - Focal Solo6 BE, Polk PSW10, Focusrite Saffire Pro 24 DSP, Lenovo x220t
    • Music/HT - Lsi25, Lsi9 (Vr3), Lsi7, LsiC, Pioneer SC-68 & BDP-62FD, PS3
  • AsSiMiLaTeD
    It depends. For movies and concerts I just use the HDMI. For 2 channel music or if a concert has a good stereo track I use the stereo analog outputs, so I'm not using the multi channel analog outputs at all. So I'm only using the DAC on 2 channel stuff and I know I could get better sound on BluRays using the analog outputs but it's not worth it to me, I'm fine with my Pioneer decoding movies.
  • brgman
    brgman Posts: 2,859
    sk88 wrote: »
    You assume correctly sir.Only way to fly with this piece.
    I’M OFFENDED!!!!
  • hochpt21
    hochpt21 Posts: 5,423
    Have you used the Oppo as a preamp, and what were your impressions? Would be interesting to see if I could replace my Dac, Pre and BDP83 with the 105, and have the same or better quality.
  • Mikey081057
    Mikey081057 Posts: 7,127
    The only CON I can think of is OJ. I don't know if I have heard of anyone not liking an oppo product. Great value. Great performer. I have a BDP-93 that I uses as player in my HT and love it. I also like their remote app for the droid. works like a champ.
    Garage | Polk Monitor 5B's
    F1nut Posts: 51,689
    DSkip wrote: »
    Was that a question or a statement? Do you have experience with it?
    More of an ah-ha. No experience with the 105, but I have heard a few of the older models. I can say I didn't think much about their sound quality, but I understand the 105 is better than those.
  • dbaldus
    dbaldus Posts: 730
    I've been considering this player lately as well. I plan to use the player primarily in DAC mode the majority of the time (connected to my Squeezebox), with the only exception being when I want to spin a few SACDs.
    I've been looking at other dedicated DACs in this price range as well (e.g., W4S DAC2) and wondering how the 105 stacks up against those. I'd really like the ability to play SACDs, but at the end of the day, if the 105 functioning as a DAC isn't as good as other dedicated DACs in this price range, I'll probably opt to give up the SACD functionality.
    Has anyone here had a chance to compare the Oppo 105 to similarly-priced dedicated DACs?
    2-channel
    Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
    Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2
  • AsSiMiLaTeD
    dbaldus wrote: »
    I created a thread about the 105 here and posted some thoughts there that will help, check that out
  • dbaldus
    dbaldus Posts: 730
    Thanks - lots of great info in that thread! For those of you interested in his review and comparison to some standalone DACs, here's the link:
    http://www.polkaudio.com/forums/showthread.php?149192-Oppo-BDP-105-thoughts
    2-channel
  • WLDock
    WLDock Posts: 3,073
    hochpt21 wrote: »
    I hear you on this. I'm interesting in using it as the center of a 2 channel temporary hybrid/HT system myself. I've listened to my buddies 95 unit but would love to have the opp to listen to the 95 side by side with the 105 next to one with the $2500 upgrade.(Not that I would ever pay that much myself)
    Reading can only take one so far....I keep reading that the 105 is SOOOO much better than all previous gens...now the $2500 upgrade is SOOO much better than the already "Legendary Status" 105 unit...and on and on. It just would be so cool to be able to hear these before spending hard earned money. I need to work on that and get connected with a local audio group/society....now that is a way to get my ear on more gear! Still, the 105 is on the radar.
  • GlennDog
    Well, it's a done deal. I've ordered the 105 and should be here next week . . . I can't wait!
    G
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • hochpt21
    GlennDog wrote: »
    G
    Nice!!!
    If you end up trying it out as a preamp, I would be interested in your thoughts. I've read mixed reviews on the unit replacing a pre-amp in 2-channel systems which is something I have considered doing.
    Anyway, congrats.
    GlennDog wrote: »
    G
    Congrats!! You will be pleased..
  • WLDock
    WLDock Posts: 3,073
    Dive right in, thats how you do it! report back.
