subwoofer sinclair?
Parachoute
Hi guys,
I want to upgrade from my old psw10 and am wondering if this might be an improvement.
http://quebec.kijiji.ca/c-acheter-et-vendre-equipement-electronique-Subwoofer-Sinclair-W0QQAdIdZ521026115
any thoughts?
Thanks for your help.
any thoughts?
Post edited by Parachoute on
Probably, having a passive radiator is usually a beneficial thing. What are the specs?Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500 -
• 10” active polyCel driver
• Dual 10” Passive Depth Radiators
• An integrated 250 watt amplifier
• A frequency response of 30Hz-150Hz
• Measures 15” x 15” x 16 1/8 -
compared to what...?Inspector 24 wrote: »Probably, having a passive radiator is usually a beneficial thing. What are the specs?
I mean, there's nothing wrong with PRs but they're not magic, either. -
I would say yes, it looks to be an upgrade from a PSW10, most subs are.
However, with only 30hz spec, I would pass. What would be your budget for an upgrade, maybe we can help a bit. Are you using this for HT or music? -
budget around 150-300$.
I use the sub only for HT. I have: Rti10, Csi3, FSi3 and...PSW10!
I'm also looking to upgrade the CSi3 to CSi5. I'm telling just in case someone would like to get rid of one of those...;).
I live in Canada, so shipping/shipping cost may be a problem. -
[smartass]mhardy6647 wrote: »compared to what...?
SVS PB13? But but not the ultra, it's too good.I mean, there's nothing wrong with PRs but they're not magic, either.
Wonder what SDA fans would say about that :biggrin:
[/smartass]
On a serious note google found me this. Seems pretty comprehensive.
http://www.aespeakers.com/PRFAQ.phpUp
Down
Parachoute wrote: »budget around 150-300$.
http://www.hsuresearch.com/products/stf-2.html
If you can wait and save a bit, there are some killer options in the ~500 range. Good luck!
