Good subwoofer match?
edited September 2013 in Speakers
I have a pair of Monitor 60 series ii speakers and a Harman Kardon HK 3480 powering them. I listen to mostly rock/metal although my GF likes to listen to rap and this setup is going to be used for parties. I was wondering what subwoofer would be a good match with these speakers. I saw the PSW10 but it seems like it wouldn't really be powerful enough. The PSW505 seems like a better option. Any suggestions?
Post edited by kadrek on
Welcome!
    A GF that doesn't listen to rap. I kid! I kid! :lol:
    afterburnt wrote: »
    Village Idiot of Club Polk
    The PSW505 is definitely a better option; the PSW10 isn't going to do much of anything other than chuff and bottom out. Remember that there is no need to match brands or timbre when it comes to subs. Honestly this little guy would be better: http://www.hsuresearch.com/products/stf-1.htmlhttp://www.hsuresearch.com/products/stf-1.html
    It will be tight and fast for your rock/metal and go lower and louder than the PSW10, and probably about the same as the 505 but more musical. Good luck!
    Game Room 5.1.4:
    Bedroom 2.1
    The PSW 505 is probably the best budget sub in the Polk line-up, but Polk really isn't known for subs. I would look at SVS or HSU. Good subs at reasonable prices. If your looking towards a more musical sub, look at sealed subs, SVS refers to them as compact. The PB and SB 1000 subs from SVS has had some really good reviews.
    Thanks for all the suggestions guys.
Welcome!
Welcome!
