Anyone have any experience bi amping Denon 4810ci?
leadfoot1
leadfoot1 Posts: 155
I have a Denon 4810ci and want to bi amp via an external amp. The manual really only covers bi amping with the AVR's internal amp so it doesn't say what pre out I would use for bi amping and the pre outs aren't labelled for bi amping.
Anyone know what pre outs to use for bi amping off this receiver to an external amp? Thnx.
Post edited by leadfoot1 on
    F1nut Posts: 52,000
    edited September 2013
    The reality is you're not bi-amping without using two separate amps and using active crossovers. Anyway, this external amp you have, how many channels does it have?
  • specd_out
    specd_out Posts: 504
    I tried bi amping my rtia5's on my pioneer vsx32. never noticed a difference. wasnt worth my time adding two new cables.
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • leadfoot1
    The external is a Rotel 1075. This is just something I want to try and see if I notice any difference.
    F1nut Posts: 52,000
    Connect the right front pre out from the AVR using a Y splitter to the amp right front and right surround, then do the same for the left. Next, connect speaker cables from the amp's right front and right surround to the right speaker running one set of cables to the top binding posts, the other to the bottom making sure you remove the jumpers first. Do the same for the left side. This is called passive bi-amping. Will you notice an improvement? Of course, you are now using an external amp, so you would notice an improvement regardless of the passive bi-amp connections.
    A better idea would be to use the external amp to power all 5 speakers in your HT rig.
  • leadfoot1
    Guess I should have mentioned I am already using the Rotel (just 2 channels of it) to power my front pair, just wanted to use more of the Rotel if I could. Didn't realize I would have to use a Y splitter. Thanks for the info F1
    Just in case I get asked this question, the reason I am only using 2 channels of the 1075 is because I used to have seperates and this is the amp I used with that setup. So just looking to use more of it if I can because I prefer the way it sounds.
    F1nut Posts: 52,000
    I see. In that case I still say the better idea would be to use the external amp to power all 5 speakers in your HT rig. At least do the front 3 off the amp.
