SDA Crossover frequencies, are they 2000Hz as published? calculations shows 1000Hz
freak1942
freak1942 Posts: 10
edited September 2013 in Vintage Speakers
Most SDA crossover frequencies as published are 2000Hz. Did some some calculations with tools from www and Vance Dickason's book, and the results with second order 12dB filters are 1000Hz.
Or is there a Polk trick I am unknown off?
Post edited by freak1942 on
  • Schurkey
    Schurkey Posts: 2,122
    edited August 2013
    Are you calculating based on "all" the circuitry/components involved?
    The SDA crossover schematics are hugely more complex than what is shown, for example, in the ERSE web site crossover calculator, where a second-order high-pass crossover is one capacitor and one inductor, while a second-order low pass is one inductor and one capacitor.
    http://www.erseaudio.com/Second-Order-2-Way
  • freak1942
    freak1942 Posts: 10
    edited August 2013
    Hallo Schurkey,
    I meant the crossover filter frequency of the Stereo driver. Thats a second-order low-pass filter.
    It has the same crossover filter frequency for the high pass. (to prevent a hole or bump, you know)
    The SDA inductor of 16 mH is for the Sub-Low, that is an other sory.
    Tomorrow I will try your ERSE calculator, but not expect difference with other online calculators.
    Now I go asleep, its midnight here in the Netherlands.
  • Face
    Face Posts: 14,340
    edited August 2013
    Using online crossover calculators are like peeing in the dark. They don't take into consideration that a driver's impedance curve is rarely ever flat, making them inaccurate almost every time.
    To get an accurate reading of a driver or speaker impedance, you need a much more complex tool such as a DATS.
  • freak1942
    freak1942 Posts: 10
    edited August 2013
    Hallo Face,
    I never realised calculator results are so far off the published 2000 Hz cross over requency.
    This morning with another online calculator shows cross over of less than 1000 Hz, remarkable.
    A soundcard measuring tool will show what is correct or wrong.
  • Schurkey
    edited August 2013
    WHICH speaker model are you calculating for?
  • freak1942
    freak1942 Posts: 10
    edited August 2013
    The CRS+ first, but other models gave the same result, at or below 1000 Hz
  • Face
    Face Posts: 14,340
    edited August 2013
    freak1942 wrote: »
    Hallo Face,
    What card, how will you be measuring?
  • freak1942
    freak1942 Posts: 10
    edited August 2013
    It seems no one can explain the big difference from the published xover frequency of 2000Hz and the calculated 1000Hz.
    Planning to make a replica of the CRS+ as close as possible, and take the result as is, no soundcard and/or software tools so far.
    Ordering drivers from Polkaudio, and new filter circuit boards from Vr3mod are on my list.
    Will also use the Dreadnought AI interconnect Avel 1000VA transformer which is still lurking on the loft.
  • Face
    Face Posts: 14,340
    edited August 2013
    I explained it, you just can't comprehend it.
    This should help: http://techtalk.parts-express.com/showthread.php?219617-The-Speaker-Building-Bible
    F1nut Posts: 52,002
    edited August 2013
    It would be cheaper to buy a pair here and have them shipped to you than it will be to build a pair.
  • freak1942
    freak1942 Posts: 10
    To Face,
    Understanding your message, thanks for PE url, great.
    To F1nut,
    Today found on Epay a CRS, ships to US only, sent seller a msg.
    Expect shipping cost as much as BuyNow price.
