Denon or Yamaha
felipe
felipe Posts: 423
edited October 2013 in Electronics
Hi all. I'm thinking of replacing my current Sony AVR (str dh520). I'm looking at denon or Yamaha. My question is which brand would be the better choice? They both seem very reputable. Any input would help. Thanks. I have polk tsi100 fronts polk cs10 center and Polk psw110 sub.
My Setup: Denon AVR X3600h, Polk Signature S50 Fronts w/ S30 Center and S15 Rears, LG UBK90 4K Player, TCL 6-Series 65”4k TV
Post edited by felipe on
    billbillw Posts: 7,458
    edited August 2013
    That's like asking which truck is better, Ford or Chevy. Both Denon and Yamaha make good receivers, each has their strength and weaknesses. For years, I was a Denon man. Then I was Onkyo for many years. Now I am a Yamaha owner. My choices were made based almost solely the price/feature ratio which of course is dependent on what type of deal you can get. I would look at all the brands including Denon, Yamaha, Onkyo and Pioneer. Get the one that is the best deal for the features you need and/or want. There is usually a sweet spot in the middle of each lineup. Also, consider some of the refurbs from AC4L.com. Usually, the refurbs are as good or better than new. If the refurb warranty is too short (some only have 90 days), consider adding an extended warranty for 1 or 2 years.
    tonyb Posts: 33,065
    edited August 2013
    What don't you like about the Sony, or your system, that's making you look elsewhere ?
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited August 2013
    Although I've run a Yamha AVR 663 for years,has worked flawless. I've learned through this site that the Pioneer Elite SC avrs are really excellent units. What is your budget, looking for new or used? There's always some good deals on avrs in the flea market also.
  • felipe
    felipe Posts: 423
    edited August 2013
    I got the Sony because of its feature/price ratio and that my other components are Sony ( TV,ps3) hence the use of bravia sync. However, lately the sync feature has been glitchy and I'm having problems with the hmdi standby pass thru feature...the picture would turn to static, or the picture n sound would cut out for a period of time. Gets kinda annoying after a while.
  • Polkie2009
    edited August 2013
    I bet that is annoying. :frown: Could this possibly be a handshake issue? HDMI cables in decent condition and making good contact?
  • felipe
    felipe Posts: 423
    edited August 2013
    My budget is about 300. New or used it doesn't matter as long as its in good to great condition.
  • felipe
    felipe Posts: 423
    edited August 2013
    I'm thinking it could Bea handshake issue. I've tried all of my hdmi cables in the house and it does the same thing..its not a connection problem as they all fit nice and secure. I'm thinking it could be a problem with sonys HDMI setup on their AVRs. Had a str dh510 before and this problem was a lot worse with that one. Didn't think my current one would have the same issue. Anyways, I found out that the denon Avr 1613 is on sale for 299.99. Researched it and it got a lot of good reviews from experts and customers alike. Any thoughts?
  • drummer86
    drummer86 Posts: 441
    edited August 2013
    If new or used doesn't matter you can buy refurbished Denons on accessories4less. Like other have stated, both are good companies so just find which models have the features you're looking for and do a little research on them. There may also be some features you didn't know you wanted so feel free to ask questions.
    When I purchased my receiver I just had no idea how important room correction software like Audessey, MCACC, and YPAO are and what the differences between them were.
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
    tonyb Posts: 33,065
    edited August 2013
    The Denon is fine for the system you have now, but it will limit you down the road should you upgrade to bigger speakers. If you don't plan on getting any big floor standers in the near future, the Denon should work well for you.
  • felipe
    felipe Posts: 423
    edited August 2013
    OK thanks y'all for your input. I don't plan on getting any big floor standers...too bulky lol. I'll post when all is done.
  • sgtmick63
    sgtmick63 Posts: 166
    edited August 2013
    I have been using Yamaha receivers since 1975. I have never had any problems with them. They have all sounded great. I started with a CR-1020 and now have a rx-a 2010. you won't be disappointed.
  • felipe
    felipe Posts: 423
    edited September 2013
    Well I ended up getting the Denon AVR-1613 new at a great price. I got it all hooked up and calibrated using the audyssey setup feature. WOOW!! What a difference in sound compared to the Sony AVR :-) It is clean and clear...vivid and good depth...and the bass...another woow! I'm hearing bass tones and notes I didn't hear before. Way to go Denon :-)
  • boston1450
    boston1450 Posts: 7,758
    Congrats felipe. Im sure that does sound very nice compare to the Sony you had. ? Do you have the TSi's on stands ? Are you running rears for 5/1 ? Ive owned a few Denons (not the newer ones) DRA435r with Klipsch SB1's in our bedroom & we love our Denon. Its a small unit but does the job fantastic..keep us updated on your impressions of how it is,as you enjoy your new Denon
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • felipe
    felipe Posts: 423
    Thanks :-) . Yep I have my tsi's on self-made speaker stands. They are 33 inches in height and weigh about 24 lbs. each. As of right now I'm not running rears...just have the 3.1 setup lol.
  • boston1450
    Nice set up. We run 3/1 in our bedroom with our Denon DRA435r @ 55wpc & love it. The TSi line of speakers are fine speakers. Easy enough to add some TSi200' & put the 100's to the rear & have a nice system at a decent price. Im hoping myself to be doing a 5/1 sometimes next spring when i can move some gear around my house. It will be a budget system & dont need a WOW system, as we dont really watch tv too much & small living room too boot. Room/space is a issue with the SDA's. it all takes time. I have plans on going with a Denon or a HK. They seem to last a long time & meet my needs. Enjoy your new receiver. Keep us updated on you impressions of it. Randy
    Randy-Maine
    by David WMG
  • Chewie
    Chewie Posts: 80
    I just got a refurbed Denon E300 for $250 with a 1 year warranty. Sounds good so far.
    Samsung PN60E6500
    Denon AVR-E300
    Mains: LSI9s
    Center: LSIC
    Surrounds: LSIFX
    Subs: Two Atlas 12's with Rythmik 350W amps in ported 95L box.
    Power: Monster 2600 power conditioner
  • Chewie
    Chewie Posts: 80
    No issues with my Denon E300
    Samsung PN60E6500
    Denon AVR-E300
    Mains: LSI9s
    Center: LSIC
    Surrounds: LSIFX
  • j1mmy
    j1mmy Posts: 95
    I'd suggest a marantz receiver. Better than anything denon in the sub $1000 arena.
  • felipe
    felipe Posts: 423
    Nice :-). I'm enjoying my denon. I got the previous version (1613).
  • RamZet
    RamZet Posts: 792
    Yamaha all the way if you had to chose between the two.
    but if you wanted to get something even more awesome try out harmankardon. Very powerful/clean units.
    http://www.harmankardon.com/estore/hk/us/products/AVR-1650/AVR%201650_HK_US?skuId=AVR%201650_HK_US&searchMode=regularProductOnly cant beat that for $350.
    Good luck hunting.
    B&W CM9Classé Sigma
  • felipe
    felipe Posts: 423
    RamZet wrote: »
    Good luck hunting.
    I heard that Harmon/kardon avrs get really hot....
  • felipe
    felipe Posts: 423
    edited October 2013
    boston1450 wrote: »
    Hey all. I recently upgraded to a 5/1 setup. I picked up a pair of Polk r40s at no cost to me (given to me from a friend) and those act as my mains and moved the tsi100s to the rear. Even though the r40s are "vintage", the Audyssey system seemed to integrate them fairly well...they sound timbre-matched now :-) This Denon so far is exceeding my expectations...can't wait to "open" up the system to see its limits :-)
  • inson71
    inson71 Posts: 90
    edited October 2013
    Congrats on the Denon. I have owned different Denon gear over the last 26 years, and I have never had any problems. In fact, I still have my PMA-500 integrated amp I bought new in 1987. Good choice and enjoy!
    Onkyo Pr-sc 5509
    Parasound 2250/Parasound 5125
    SVS PB 12 Plus
    Denon DBP-2012 Bluray
    Polk RTI 8, CSI 3, 4 FXI 3
    Sony 55" LCD
