Speaker Jumper Questions
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited August 2013
    No scientist here but dosen't brass if not at least gold plated tend to corrode esspcially in a wet/ humid climates way faster then the lenght of a minute exposed 12 gu at the binding post or directly through the hole if it's a true 5 way, also mentioned for what ever reason they can loosen up.
  • Tornado Red
    Tornado Red Posts: 939
    edited August 2013
    Brass is funny stuff, an alloy made of copper and zinc. Since it doesn't contain iron, it's a non-ferrous metal and cannot rust but...it will corrode over time. Tarnish is another way to put it. I suspect from the lack of weight of the jumper strips, at least on my speakers, that though they may contain some brass, I suspect some other metal(s) as well. None of it very expensive and perhaps not as conductive as one would like them to be.
