My PFB moment...
nooshinjohn
Well guys, I finally had a PFB moment I will not soon forget. We have been struggling with cell reception here at the house for some time, so I finally got a signal enhancer from our service provider and set about plugging it into our network. I set everything up and it worked well.
The device was placed on top of our fireplace mantle as it needs to be up high to function correctly. While we were asleep, the cat and dog decide to chase one another around the house, and one of them gets tangled up in one of the cords, pulling the device off the mantle.... and onto one of my amps!
I lost a couple tubes, which were easy to replace, but the transformer cover will need to be repainted by a local body shop. I will lose the inscription Bob signed on the back, but thank god I built them as strong as I did or the damage would have been much worse. It does not show in the picture very well, but there are two small dents in the cover, otherwise I would just buff this out, because the damage never got through the clear coat....
Post edited by nooshinjohn on
Ouch!Political Correctness'.........defined
President of Club Polk -
I would probably just clean them up as best as you could and keep the Carver inscription rather than loose it in the repainting.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Sorry about the accident John.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Sorry to hear that John.
See, Emo Kitty strikes again. Dogs are good judges of character, and yours just happened to see right threw that Emo kitty pretending to be a regular house cat.HT SYSTEM-
lsi 9's -
Hopefully a easy repair. Things just happen. Even when trying to avoidRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
I hear that cat skin transformer covers are the next big thing! Just a thought!Enjoying the journey while never attaining the destination.
John, here's the important question...
You had both a cat and a dog when this happened. Do you still have a cat and a dog, or is one of them MIA all of a sudden
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Anyway a brick fireplace mantle is a poor place for a signal booster. High frequency radio waves struggle to get through thick brick walls.
^^^ Seconded - with the clear coat intact a little dent or two + Bob's sig gives it character."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
I don't know guys, John and Bob Carver hook up every Sunday to take in an afternoon show, share a bucket of popcorn. It would be easy for him to get another sig.HT SYSTEM-
lsi 9's -
All kidding aside. I think that a professional auto detailer could fill the nicks with paint (hopefully you have some left over from the build) and buff it out so that the scratches would be tough to see without close up inspection. They use a single hair brush to fill small scratches. They build it up a little at a time until they have enough material to match the thickness of the original paint. Then they wet sand with 1000 grit followed by a buffing process. The dent may be popped out to some extent as well using paintless dent removal methods. I had this detail work done to my truck, and the results were fantastic! Door dings were gone, and many of the nicks, scratches, and chips were not detectable.Enjoying the journey while never attaining the destination.
+1 If not this they may be able to do a partial paint, and either burn in the clear at one of the curves or just clear over the sig. I'll think you should be able to save the sig one way or another... -
Maybe it's an opportunity to customize even more. How about a nice piece of cherry wood on the top with the word "Carver" burnt into the wood.HT SYSTEM-
lsi 9's -
Ummmm... No, but thanks for the suggestion.
Two estimates so far put the price at 400.00 to repaint. At this time , not really an option. Paintless dent removal is also out due to the thickness of the material. I am thinking about using a two tone approach that would use a contrast color on the tops of both covers. This was I don't have to rework the whole thing, but any descision made will be a ways off and done with extreme caution.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Ok, big guy....another idea. Have someone airbrush your favorite album cover on the top. Now that might look cool.HT SYSTEM-
lsi 9's -
How about a portrait of Bob Carver instead
.... that would make it even better....
Besides the album cover for "Whenever You Need Somebody" by Rick Astley wouldn't look good, nor would "Playing with Fire" by Kevin Federline
nooshinjohn wrote: »Ummmm... No, but thanks for the suggestion.
$400 for a repaint is just crazy! I had my whole truck detailed as described for just under $200 and that included steam cleaning the interior! This should be less than $100 (IMHO) based on my experience with detailers. Prices like $400 are "We aren't interested" numbers! Keep looking, and you will find someone who needs and wants the work.Enjoying the journey while never attaining the destination. -
The cover is in the shop now.... after careful consideration, I have decided to restore it, and if it needs to be sent to Bob for a new signature, so be it. I have way too much blood, sweat and tears in these amps to NOT get it fixed. The shop that does the work for my dealership is going to do it for the princely sum of pay the painter a hundred bucks and a 12 pack of Corona and all is good.
I compare this to finally getting your dream muscle-car fully restored and some kid dings the door with his bicycle or something. On the surface, you would try and be cool, but inside every time you look at that spot, it would drive you nuts. I get it back in a week.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Shoot, I would have just put a potted plant on it to cover it up.
nooshinjohn wrote: »The cover is in the shop now.... after careful consideration, I have decided to restore it, and if it needs to be sent to Bob for a new signature, so be it. I have way too much blood, sweat and tears in these amps to NOT get it fixed. The shop that does the work for my dealership is going to do it for the princely sum of pay the painter a hundred bucks and a 12 pack of Corona and all is good.
That is awesome! Definitely the right decision. I'd hate to see you settle, knowing that it was not right.
You should send the other cover, too! This way the painter can compare his results to the original. The paint appears to be a metallic finish, and as such, it matters how it is applied for the metallic flakes to reflect in the same direction. If it is not applied the same, it may appear lighter or darker as compared to the original paint job. Good luck!Enjoying the journey while never attaining the destination. -
Great news... I made the right call in getting the cover fixed. The shop expertly matched the color so that even I cannot tell what was original and what was not. They were able to use the curves on the front and back to feather the new paint into the original color, as well as perfectly match the mica content of the paint and the way it lays down so light refraction is an exact match.
The best part is the original signature and pinstripe are untouched!
Will post a pick or two before I put the cover back on.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
That is great! Now you need a way to keep it from happening again! Cat repellent?Enjoying the journey while never attaining the destination.
No cat.... or no dog.... whichever you love more
No pets here, boys! No worries, no duties, no walking anything, no feeding, no cleaning up after, no accidents. PRICELESS!
I must have gotten up on the wrong side of the bed today because every post I've made is that of a crotchety old man?
cnh
Know what ? Your allowed my friend. God knows I have those days too and more than I care to admit.
I guess John is now an official member of the PFB fan club. A t-shirt John, is right up your alley. Put in your order and color preferences early, I have a feeling they'll sell like hotcakes.HT SYSTEM-
lsi 9's -
now that there is funny ROLMAO. Carry on. Glad you were able to save the signatureNo pets here, boys! No worries, no duties, no walking anything, no feeding, no cleaning up after, no accidents. PRICELESS!
cnh
Randy-Maine
by David WMG
I was going to join actually until I found out I would have to dress like Elton John for the annual PFB weenie roasts...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Just courious, where is that cat now??? The dogs stomach perhaps!Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
The cat was shipped off to Lightman's new pad.....apparently he eats these things.HT SYSTEM-
lsi 9's -
So let me get this straight. You are saying that Lightman eats pus...?
Tom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
