Pressure cookers...which one?
treitz3
Hello folks. This past weekend while on vacation, an irreplaceable piece of my tried and true pressure cooker has failed [missing a piece]. That was the pressure release valve that is normally would be replaceable but unfortunately, not on the unit I have [Innova model 42108] due to it's location on the handle. In searching the web today, I have narrowed my search down to two models.
Fissler Vitaquick 10.6qt.
http://www.metrokitchen.com/product/FS-60070010079?utm_source=nextag&utm_medium=scs&utm_term=FS-60070010079&mr:referralID=d72a7756-082b-11e3-9dea-001b2166becc
or
The Fagor Duo 10qt.
http://www.chefscatalog.com/product/28061-Fagor-Duo-Stainless-Steel-Pressure-Cooker.aspx?utm_source=nextag&utm_medium=shopping&utm_content=28061-1000&utm_campaign=Fagor&sourcecode=EW1CS1018&gdftrk=gdfV23800_a_7c2214_a_7c9325_a_7c37915
Both have been top rated for ease of use, safety, convenience, no hot spots or burning, minimal water loss, quietness while cooking as well as having a consistent internal temperature. While one is a "frugal" type pressure cooker, the other is a professional cooker that in theory should last a lifetime. I was just wondering if any of you and/or your wives have used either model and could offer some real world experience.....or if you have another suggestion I haven't ran across yet. Looking for at least an 8qt. cooker because you can only fill up the pressure cookers to 2/3 capacity and *most* recipes will call for a pressure cooker at least this size. One can always cook in a bigger cooker with the same results but this can not be reversed into a smaller cooker.
I have been spoiled with the Innova over the years and this is something that I most definitely consider a staple for the kitchen in my household. Any comments or suggestions are welcomed and I look forward to any input you may have to offer.
or
The Fagor Duo 10qt.
Post edited by treitz3 on
I use a Fagor myself. Great build quality.
The CIA and NSA are tracking you now. :cheesygrin:"I did not slap you. I high-fived your face."
Yes , dont email or call as i dont want to be on the list with you
LOLMain Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Red Flag words....really,my grandma from the old country used one of those...cooked sheep tongue in it and sliced it thin,was very good
Alright, I posted this same question on another forum and they basically said the same thing.....what gives with being on a CIA/NSA watch list? I plan on using mine for canning, pressure cooking and steaming. I have nothing to hide and they are more than welcome to come and see my kitchen but now my curiosity is up. What gives?
Pretty much the same thing I said on another post...someone took the whole thing wrong....o well...
I'm curious myself. Anybody care to explain ?Alright, I posted this same question on another forum and they basically said the same thing.....what gives with being on a CIA/NSA watch list? I plan on using mine for canning, pressure cooking and steaming. I have nothing to hide and they are more than welcome to come and see my kitchen but now my curiosity is up. What gives?
Tom -
Boston marathon
Got one of those Wolfgang Puck models for Christmas. Only used a few times, but seems to work well. Only 7 qt capacity, but still fairly good
Now that.....may explain a thing or 2.
Just messin' with ya.HT SYSTEM-
lsi 9's -
A pressure cooker, with Wendy's so close? LOLSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
which one holds more powder
