Realize this isn't audio but would like some help with a wire question?
drselect
Trying to repair my daughters hair straightener and need some help trying to figure out what type of wire to use. It does not appear to be copper and it appears to have a coating that is not a standard plastic. Thought it may be something hear resistant. Also as shown in one of the picture where the wire are connected together the "shrink" wrap is different than what I have seen before. Have tried searching the net but most of the stuff I have found is related to replace the power cord not the internal wires. Realize I could just buy another one but what fun would that be. Any suggestion on the wire and connecters?
Thanks.
Thanks.
Post edited by drselect on
Get in touch with Polkfarmboy, I'm sure he has something you can use and you'll probably end up gettin it for free!!!!!!If you can't hear a difference, don't waste your money.
Yep, a 11,000.00 cord for a hair straightener.
Nice¡¿Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
You guys are relentless.
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I would just buy here a new one. The risk of her hating you for creating a device that torches her hair, thus ruining her social standing is just to great.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
nooshinjohn wrote: »I would just buy here a new one. The risk of her hating you for creating a device that torches her hair, thus ruining her social standing is just to great.
Ditto on nooshinjohn's advice.
I tried to repair wires in one of my daughter's straightening irons. Although she did not "torch" her hair with it, it never quite did the job. They don't make these kinds of devices to be repaired. But then, I'm not an expert with these kinds of repairs.
Surprise her with a brand new ceramic one; perhaps, her smile will be enough fun to make it worthwhile for you!
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Classic...
http://youtu.be/LdVuSvZOqXM -
yea $10 why bother chickadee china
http://www.walmart.com/ip/14282405?wmlspartner=wlpa&adid=22222222227000427977&wl0=&wl1=g&wl2=c&wl3=14005330750&wl4=&wl5=pla&wl6=34925076550&veh=semPOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
I have been trying all day you to use an old pair of jumper cable I have to repair this thing but I just cant figure how to fit all of it back into the small space of the straightener.
I figure I will have to buy her a new one but I shelled out so much for this one (because I thought it would last more than one year) that just out of sheer principle I want to try fixin it. And by chance I do figure out how to fix it I will than have something to straighten my chest and back hair.:cheesygrin: -
Try some Teflon coated copper wire. Usually you can find mil-spec on the internet. Teflon is heat resistant to a very high temperature, several hundred degrees."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
