What type of surge protection for AMP's?
chiptouz
chiptouz Posts: 152
edited August 2013 in Electronics
All I have the Monster HTS 3600 for almost all of my components. I am concerned if I should hook up an Emotiva XPA-5 to this and think that I shouldn't. How do we protect this kind of equipment that draws so much power? What do you all use to protect your amplifiers and other equipment from surges?
Thanks,
Chip
Sharp LC-80uq17u
Denon 4520ci Receiver
OPPO BDP-203 Blu-Ray Disc Player
Monster HTS 3600
Polk RTi-a7 (fronts)
Polk CSi-a6 (Center)
Polk TC-60i (Rear & Surround Rear)
HSU Research VTF3-MK4 (Sub)
Logitech Harmony elite (Remote)
Post edited by chiptouz on
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2013
  • Speedskater
    Speedskater Posts: 495
    edited August 2013
    First - the surge protector should be a whole house unit at the electrical service entrance of the home (main breaker box).
    Second - a point of use surge protector only looks at the incoming voltage, it doesn't care about the load level.
    tonyb Posts: 33,072
    edited August 2013
    Plug it straight into the wall. The usual power conditioners, consumer grade, have a certain current limiting factor to them which then begs to question why you would limit current to an amp. Higher end conditioners are better and non current limiting but cost some coin over what you have now.
    Whole house units is probably the ticket but again, aren't cheap.
  • Tornado Red
    Tornado Red Posts: 939
    edited August 2013
    To what SS said here. Last week I installed 2 dedicated 20 amp breakers with 2 Leviton 5380-W 20 amp surge protected wall plugs for in house surges and a SyCom-120/240-T2 whole house protector, good for 100,000 amps for outside surges like lighting/utility company errors. All are available at Amazon, the 2 wall plugs are around $33 each, the SyCom is around $76. The install for the SyCom I found to be quite easy as a DIY project if you're comfortable with such things. Anyway, just another idea for you.
  • Bob in WI
    Bob in WI Posts: 155
    edited August 2013
    I guess I just don't get it. I have a little better than normal power strip & I turn it off when I'm done listening. All my electronics are connected similar, TV/ surround, stereo set up & PD/ printer/router....all on power strips& turned off when not in service. I like the idea of whole house or entire circuit protection tho. I'm assuming this is different from a GFI.
    F1nut Posts: 51,805
    edited August 2013
    The transformer in your amp will deal with power surges, so just plug into the wall. Power strips using MOV's (almost all power strips use MOV's) are crap for surge protection anyway. One good spike and it becomes a throw away item.
  • Speedskater
    edited August 2013
    Bob, the power strip surge protector, protects against high voltage spikes on the AC line.
    A GFCI (Ground Fault Circuit Interrupter) monitors how much current is flowing out the Hot wire and how much current is returning on the Neutral wire. If these two values are not almost exactly the same, it means that current is going someplace that it should not go and the GFCI turns the circuit off.
