How much power is needed(wanted)?
PixelPusher
PixelPusher Posts: 16
edited September 2013 in Speakers
I am building out my first home theater and I am looking to add some more power to the speakers now that I am out of an apt. This is my current 7.1 setup:
Yamaha RX-A1020 (doing all the work right now)
2x Monitor 75T
Monitor 25C
2x Monitor 40
2x Monitor 30
Klipsch SW-350
I would like to give the speakers as much power as they/I can handle so when I upgrade, which we all do :), I will have enough to power some larger speakers. I see some people here saying that the 75Ts can handle 300w but the rating is 20-275 so I am confused. I also saw someone saying they are pumping 200w to a CS2 and the rating there is 175.
Could someone give me a little clarity on how much my speakers can handle and how I can get the maximum out of them?
Post edited by PixelPusher on
    tonyb Posts: 33,069
    edited August 2013
    Speaker power ratings are more so a guideline rather than something etched in stone. Any speaker can benefit from more current being available to them. A lot has to do with how loud you listen in a given size room too. For average volume, what you have is fine. Keep in mind though, on your average receiver, the more speakers you add the less power is available to all. A tad more complicated than that but that's just putting it into a simpler version. Which is why some go for adding an external amplifier for the front 2 or 3 speakers and let the receiver handle the others. Also, a 300 watt per channel amp doesn't pump all that power out as soon as it's turned on, it's just available should you need it. Follow ? The higher you turn up the volume, the more juice your speakers need, the more power the amp puts out, up to a certain point anyway. Everything has it's limits.
    Now, what you didn't say was what you planed to upgrade to. Be more specific and we can recommend a course of action.
  • PixelPusher
    edited August 2013
    Thanks for the info! Most likely I am going to stay in the Polk family and get something from the RTi or RTiA line. I can't stop looking at the RTi 10s on Polks eBay store. So going forward I would most likely go to that line of speakers, RTi/CSi/FXiA.
    So would getting something like a 3x200 amp do the trick for the front 3? Or should I give the 75Ts more power. I do like my movies loud :) With my Yammy I had the volume level at -10 if that means anything :/
    tonyb Posts: 33,069
    edited August 2013
    The RTI10's could sure benefit from an amp and if you listen that loud, I would say it's a must have then. Just make sure you have preouts on the receiver to add an amp in the first place. Just remember if you do add an amp, doesn't mean you can go crazy on the volume dial either. Amps are for clarity/dynamics....not volume.
  • PixelPusher
    edited August 2013
    My RX-A1020 definitely has pre-outs so I am set there. I wonder if I listen to it so loud right now because I need more power to get that clarity/dynamics at lower volumes. Does that compute? So a 200W amp should be fine for the 25C?
    tonyb Posts: 33,069
    edited August 2013
    Could be my friend, especially if your trying to achieve certain loudness in a bigger room. Takes more current to reach those SPL's, something a receiver usually lacks at higher volumes with all those speakers attached.
    So this is going to be for HT and music listening....or just HT ?
  • PixelPusher
    edited August 2013
    Probably 95% HT
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2013
    Yes a 200wpc at 8ohms amp will be just fine. But don't discount the fact that the back speakers will benefit just as much from that kind of power as well.
    The speakers will only take what they need to operate to their full potential, but the power has to be there for them to take it. That is why we like to recommend separate amplification. Welcome to Club Polk!
    tonyb Posts: 33,069
    edited August 2013
    Did I say welcome to the club ? Sorry man, my manners are terrible at times.
    Welcome to the club !!
  • PixelPusher
    edited August 2013
    So 200wpc to the 40s and 30s would be fine too?
    tonyb Posts: 33,069
    edited August 2013
    Cool bro, start with amping your front 3. The surrounds will get more juice anyway from the receiver if you take that burden of the front 3 off of it. Frankly, the surround position is the least power using position in HT anyway.
  • PixelPusher
    edited August 2013
    Well it looks like I am off to find a 3x200 amp. I am liking the prices of the 5503 and 1203, now I just need to offload a Marantz 6005, any takers? :)
    I have heard that the RTis are brighter than the Monitor line, I usually like speakers leaning toward the warmer side. Any suggestions on a warmer amp to combat the inevitable upgrade I will make.
  • PixelPusher
    edited August 2013
    Any thoughts on the Emotiva XPA-3 compared to the Parasound and Adcom? There is a guy on craigslist near me selling it for $450
  • zingo
    zingo Posts: 11,258
    edited August 2013
    A good starter amp, but does not have the sound quality of Parasound.
  • chumlie
    chumlie Posts: 8,658
    edited August 2013
    zingo wrote: »
    I'll second that, but if your looking for HT use I would get the EMO in a minute. I doubt you would notice much difference for your application.
    tonyb Posts: 33,069
    edited August 2013
    Warmer side ? Parasound or my personal favorite B&k. Check Audiogon.com or your local craigslist to start.
  • heartystatue
    heartystatue Posts: 329
    edited August 2013
    I am currently using the xpa-3 in my setup for ht f, c, l, and reciever for the rears. A major upgrade from just using the Onkyo. Thats a good price too. Welcome to CP.
    HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
    2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC.
    edited August 2013
    Emotiva is fine, but like Tony I'd prefer the Parasound or B&K. But maybe we should wait for yahzi to weigh in on how much POWER one needs? What do you think guys? I'm waiting for our resident "engineer" to get those numbers up. I'm so enamored of hardcore "tests" and "graphs". My god, I'd never buy anything "I" thought sounded "good" without "looking at the numbers"!
    Excuse my aside above--we like to have some "fun" around here, too!
    cnh
  • PixelPusher
    edited August 2013
    Thanks so much for the info guys! I ended up going with the XPA-3 from a guy on AVS (craigslist dude never responded) for $450. I really wanted to get something like Parasound or B&K but I am always a little scared getting something that old without seeing it.
    Now I just need to set the theater up, can't wait!
    tonyb Posts: 33,069
    edited August 2013
    Absolutely CNH, a little fun with some good debate= thick skin....which seems to be sorely absent these days.
    tonyb Posts: 33,069
    edited August 2013
    Cool man,wouldn't be my personal choice with RTI's but hey, should work fine as a starter amp. Now since that's out of the way and seeing your choices, I would recommend you look for a warmer sounding cables to hook it all up. You have thought about cables haven't you ?
    F1nut Posts: 51,713
    edited August 2013
    So, in the span of what about 8 hours you researched amp options, found a guy on the AVS forum that lives near you and bought an amp that almost everyone suggested was not the best choice? I've got a bridge for sale, you'll love it.
    Yeah, some seriously warm cables. Try Cardas, they might help that combo.
    heiney9 Posts: 25,430
    edited August 2013
    Jesse,
    I've found many people come here for validation not advice. He obviously already made up his mind 8 hours before he posted here.
    F1nut Posts: 51,713
    edited August 2013
    You have a good point.
    tonyb Posts: 33,069
    edited August 2013
    Maybe so gents, still....no need to jump on the dude. His Yamaha + emo amp + RTI's = some serious bright sound. My only hope is he doesn't dive in for the Monoprice stuff. That would put it over the edge.
    I am curious myself however, we did give him some good recommendations, yet he went another route. Eh, to each his own, but if AVS is his source, why not ask the same questions over there ?
  • PixelPusher
    edited August 2013
    Well, you guys have officially made me second guess my choice haha. I went with the Emotiva because is is much newer and comes with a warranty. I had been contemplating getting something from Parasound, Adcom, B&K or Emotiva for a few days now. I know it wont sound as good as the other recommendations but maybe when I have a little more cash to spend I can upgrade to a newer amp from a better brand. I am always nervous buying old equipment so I stayed safe :/ Plus if I dont like the sound I could turn around and sell it for close to what I paid and get one of the recommended.
    Now on to cables... I had no idea they would could change sound characteristics. Please give recommendations!
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2013
    Your Emo is fine for a new HT. It gives you a base on which to grow, and as you change gear you will be able to make mental comparisons as to which you like better. In fact, comparing the Emo to the Yamaha is your first task.
    In regard to cables, unless they are really cheap they won't change the "sound characteristics". That is called distortion. What good cables do is get out of the way, and let your gear perform at its potential. I was totally amazed at how much sound I was able to extract from my modest gear as I upgraded the power cables, interconnects, and speaker cables.
  • sponger
    sponger Posts: 325
    edited August 2013
    I'm sort of in the same situation except I've forgone stepping up to the RTi in favor of seeing what more power will do for the Monitors first.
    Emotiva seems like the best bang for the buck, but I'm leaning towards the domestically manufactured Outlaw brand. It's the least I can do to make up for buying a foreign car. People seem to say Outlaw stacks up well against the usual suspects of budget amps, so I see it as a win-win.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
    F1nut Posts: 51,713
    edited August 2013
    PixelPusher, I already suggested Cardas as being a warm cable.
    BlueFox wrote: »
    I can't agree with that. Once you get past the standard xx gauge stranded cables, the selections have a different flavor that has nothing to do with distortion.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited August 2013
    Welcome to the CP forum PP, too bad you didn't try and find an Emotiva right here being sold by a Club Polk member,
    they tend to show up quite often in the CP flea market.:cheesygrin:
  • Geoff4rfc
    Geoff4rfc Posts: 2,814
    edited August 2013
    OP, welcome aboard. You'll notice right off that the word Emotiva affects some like the name Jesus; offense, anger and rejection.
    Your XPA-3 works great with the speakers you have. An XPA-2 works even better in a 2ch configuration for those mains.
    As far as speaker wire goes, the Monoprice 12awg I use is inexpensive and also works great.
    With good speaker placement and set up, you'll be able to achieve a really great sound.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
