tv woes and ? / w then the problem
leftwinger57
leftwinger57 Posts: 2,917
edited August 2013 in Electronics
1st the question.The way my tv is set up is 1 HDMI cable from tv input1 directly in Cablevision Box. Hdmi input 2 goes to the output of my Yamaha rx-v665 so I get the on screen Yapo adjusting deal. Then I run either a Toslink or RCAs out of the cable box into audio 1 of the Yamaha to pick up audio. Now I do it this way so I can have silent t.v.and listen to tunes at the same time ,I like the variety and you cannot do this w/ just 1 HDMI cable. Is there an avr w/ such a feature or am I the only one who does this?
Now the problem,last night watched t.v. everything was fine vid aud everything.This morning freaking garbage trucks are dumping dumpsters and wakes me up. So I go into the living turn on the t.v. and cable box and no video.
I'm hearing audio,no video. I go to make sure all cables are seated correctly and they are.I immediately called Cablevision and the dispatcher asked a few questions like do you see a no signal icon floating around the screen,no.Can you change inputs from your Toshiba's remote no,can you change stations w/ the cable remote yes.I see here your on chl 2 is that correct yes.She says maybe your input 1 is beat and could I switch to 2, no it's a hung t.v. and a 2 person job.Now I pulled that 2nd HDMI out of the Yammy just to see if the 1st cord was beat, no so it must be the port I guessing , they are coming anyway and if I throw the guy a $10 spot for sorting this out so be it.
  • leftwinger57
    edited August 2013
    If my t.v. is beat did any of you guys buy a new t.v. on line and obviously get it delivered .Or is it best to go the store directly and not worry about UPS and or Fed EX whom ever delivers these things.Would a 42'' be to big to ship?
  • monepolk
    monepolk Posts: 1,154
    edited August 2013
    So you tried removing the HDMI from the yamaha and plugging it into your cable box and then switched the TV to that second input?
    Can you see the on screen info from the yamaha before you go through the trouble of changing things?
  • leftwinger57
    edited August 2013
    No on screen anything.My Toshiba remote will not even let change inputs at all. In the interim also called Toshiba and of course it's a 9y/o tv out of warranty but they did walk me through a master reset and it looks like my tv has a difinative power problem and looks like I have to UPGRADE.Cablevision is still coming Tuesday just in case I missed something and I requested the same tech so he knows my covoluted faccata system .About switching posts it's a hung tv I can't do by mself safely I also have a VGA CABLE from my computer to watch You-Tube concerts and such.So , we will see Tuesday ,then if it's shot I'll throw a towel over it and bring my bdrm tv into the living room which of course is way smaller run it till possibly Labor Day sales.Of course w/ my luck my bro-inlaw does not work at BB anymore so no discount there. I'm fd either way.
    tonyb Posts: 33,066
    edited August 2013
    Save your pennies, always fun to go shopping no matter the reasons why. Sucks this stuff always happens at the worst of times. Like there's ever a good time, right ?
  • monepolk
    edited August 2013
    Sorry to hear that the reset didn't help. Now on to BIGGER and better.:biggrin:
  • leftwinger57
    edited August 2013
    Ye really, It never ends but it WILL BE BIGGER.Thing I was just going to call Signal Cable today to get some new cables now that's on hold for sure but my SDAs are working just fine .Thanks the Lord for small favors.....Lew
