LSiM703 Speaker Stands
OK...My new 'refurbished' 703's will be here Wednesday from Polk eBay. Thank you everyone for helping convince me to choose the 703's over the RTAi7's.
Now I'm in a quandry. I need speaker stands. I see a few here have listed stands that sell for $300 and up. Not to sound sarcastic but if I planned on spending that much for stands it almost sounds like towers may have been a choice I should have looked at harder....even though the 707's or 705's are quite a bit more.
The stands at kind of caught my eye that look like they may be sturdy enough for me are made by VTI. They have two relatively large diameter vertical tubes and the top plate looks like it should be able to hold the 703's....I hope and I believe I saw they sell for around $130 a pair.
I really do not want to drill holes in the bottom of the speaker. Another suggested using velcro, which may not be so bad. Its just me in my condo for now. I do not own pets or children. Though I may turn up the volume I don't plan on cranking it up so loud that a seismograph will look like one of my lie detector tests.
Any suggestions? Thanks again!!!
Post edited by Sprags on
Give the VTI a try,I know you don't want to spend 300.00.but sometimes its money well spent.
Some of the guys like these.
http://www.audioadvisor.com/prodinfo.asp?number=SAUF
If your handy you can make some.
Dan -
I am handy...I just don't have the resources right now. The ones listed are the ones that are $300. I see they weight 35 lbs. but so do the ones that are half that price. I see the speaker shelf is smaller. I can't see the larger shelf justifying them costing twice as much. What is it about the ones in the link that justify them costing that much?
The only stands worth buying are the ones from Skylan or the Sanus Ultimates, IMO. VTI stuff is cheap junk.
Don't use Velcro and don't drill holes. Either spike the speakers or just place them on the stand.Political Correctness'.........defined
President of Club Polk -
+1! The speakers won't fall off no matter what volume they're played at.Don't use Velcro and don't drill holes. Either spike the speakers or just place them on the stand."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
LOL....
Let me add to my previous comments. Stands do make a difference. The ones from VTI are all steel and resonate like crazy. The ones from Skylan are made from MDF and PVC, completely non-resonating. The Sanus Ultimates are made from steel and a heavy composition base. They use cork gaskets between the top plate and the columns to help elimanate resonating. Both put a lot of thought and R&D into their products, which shows. You would have no problem seeing and hearing why they cost more.Political Correctness'.........defined
Honestly the only reason I haven't given the Lsi9's or Lsi7's a try is because i'm not willing to stick them on cheap stands and they do get expensive quick. Like everything in life you get what you pay for, and i'd do it once and do it right and not have any regrets. You're going to have an awesome setup!
http://www.amazon.com/SANUS-SYSTEMS-SF-30B-Steel-Speaker/dp/B0006885FS/ref=sr_1_20?ie=UTF8&qid=1363056757&sr=8-20&keywords=sanus+stands
I use these and I'm happy with them, though I'll admit I've never had better stands. I've got them filled with sand and they are very sturdy.Things work out best for those who make the best of the way things work out.-John Wooden -
Thanks F1nut for making me aware of Skylan; Pleasure to deal with and awesome standsTV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables -
Bdtae which model Skylans are yogurt lism 703's sitting on. I have a pair of 703's and they look like really good ones. Thanks much.Regards, Bob
Samsung PN51E6500 Plasma
Marantz UD 7006 7.1 Blue Ray/CD/DVD Player
Marantz SR 7007 HT Procesor
Polk LSiM 705 Fronts
Polk LSiM 706c Center
Polk LSiM 703 Rear
Klipsch RW12D Sub
Music Hall 5.1 SE TT -
Are you a Hokie or Cav Fan? HTTR I hope! There the Sky 28 D; with modded plates.TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
You are welcome, sir. Have you mass loaded your stands?Political Correctness'.........defined
