New Round Aluminum Plates
VR3
Not labeled yet -
These are T66, Aircraft grade - HAND MACHINED right here in the USA
Post edited by VR3 on
Oh, snap!
I am doing a test batch, one pair, that will be powdered coated black and labeled in white lettering- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Oooooooooo... Better not let my other half read this. She may want green plates! :razz: -
LOL! I actually spoke to the machine shop and pretty much any color you want we can have done, we would just make them to order. This new shop is going to open the doors for a lot more stuff than before. He is a great, very talented friend of mine that has been making a lot of the things you see me use, like the shelves and so forth!
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Those will go great with my new square granite glasses
hehe, here is the new Rectangle plates- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Touche' my friend!
Those look very sweet!
Is it difficult to make the holes for the BP's with a flat side, ala Cardas, to prevent them from turning when you tighten the BP nut?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
