onkyo tx-nr 626 with polkaudio rti a7 ??
bedijn
bedijn Posts: 2
edited July 2013 in Speakers
hello is there anybody who can tell me if my onkyo tx-nr 626 can power two rti a7's or maybe can give me some advise about whats a better size floorstanding speaker i should take for this receiver.
greetings from spain
Post edited by bedijn on
    tonyb Posts: 33,065
    edited July 2013
    Sure it can, I would not go any higher up the chain though with that receiver. No preouts means you can't add an amp down the road should you want to move up to bigger or better speakers.
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2013
    I would upgrade the receiver before the speakers. Those speakers are great and the more clean power you give them the better they will be.
    Main Surround -
  • bedijn
    bedijn Posts: 2
    edited July 2013
    thank you for your quick response!! yes thats what i was afraid of not having pre outs.
    i dont want to have bigger speakers as long as it can fire up the a7's i want to buy. its just a small livingroom of 25 sq/meter.
    i just buy the receiver so now i have to buy the speakers that fits the receiver.
  • nguyendot
    edited July 2013
    That should pair fine then.
    Main Surround -
