School me on CDs/SACDs and players
ipsullivan
ipsullivan Posts: 65
edited July 2013 in Electronics
So the Sony CD player I have now is junk and I am looking to upgrade to something that can play SACDs. I don't know anything about them so any advice on what direction to go would be great.
I am finding that I am loosing clarity or gaining static/crap noise from certain audio tracks and I am pretty sure it is the mp3/mp4 files. Because I am hearing the same junk at the same time when I play it in my car.
Are SACDs the best format of CDs? Will there be a noticeable difference with a better CD player? Is there a way to burn SACDs?
Thanks in advance,
Ian
Post edited by ipsullivan on
    F1nut Posts: 51,747
    edited July 2013
    Generally speaking, yes.
    Always.
    Not really.
  • deronb1
    deronb1 Posts: 5,021
    edited July 2013
    There.are some very nice sonys that also play sacd. If your system is mid fi, you might want to consider a sony sacd and see if you like the format. Sony has been doing it a long time
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited July 2013
    Garage | Polk Monitor 5B's
    tonyb Posts: 33,072
    edited July 2013
    Before you stick a knife into the cdp, you say your digital files sound like crap in the car. This obviously means you are downloading the cd's into your computer, yes ? Maybe look at that first, the program and settings your using to do that conversion.
  • ipsullivan
    edited July 2013
    tonyb wrote: »
    Right now any CDs I burn are done through iTunes, some songs were imported from CDs, some from iTunes and various sources.
    tonyb Posts: 33,072
    edited July 2013
    Do you have the error correction on ? Are you downloading into apple lossless or a MP3 format ?
  • BlueFox
    BlueFox Posts: 15,251
    edited July 2013
    ipsullivan wrote: »
    itunes only sells lossy MP3 files. You cannot buy lossless files from iTunes. Buy a real CD from Amazon, or other places.
    tonyb Posts: 33,072
    edited July 2013
    I'm still at a loss here as to why the cdp is at fault when the complaint stems from digital files.
    If your dead set on a new cdp, on a budget look for an older Pioneer AVI 59 or 79. They are universal players but are darn good as cdp's and SACD players too. Can be had under 150 bucks also if you look hard .
  • ipsullivan
    edited July 2013
    tonyb wrote: »
    Maybe it is not the player, it was a dvd/cd player that came with a 5.1 system back in 2007 or 2008. I guess I just figured it was lacking due to cheap price point.
    I think it would be worth while getting a player that can do SACDs also.
    tonyb Posts: 33,072
    edited July 2013
    It may be lacking....not questioning that. Hence my suggestion for a player, but also look at how your converting files, what kind of files/programs used, etc. Could be your player in the car is screwed up too or of not great quality.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited July 2013
    The two top Sony Blu-ray players 5100 and the 790 will play SACD and a lot of other things.
  • Msabot1
    Msabot1 Posts: 2,098
    edited July 2013
    Hey guys...have a cd player that is HDCD compatible.....is this the same format as SACD? HK makes it..seems to be good equipment.....thanks!!
  • PolkieMan
    edited July 2013
    No.
    http://en.wikipedia.org/wiki/High_Definition_Compatible_Digital
    Msabot1 wrote: »
  • ratster
    ratster Posts: 324
    edited July 2013
    ipsullivan wrote: »
    Thanks in advance,
    Ian
    There is a pretty good thread about cd/sacd in the learning center on Audiogon that might be worth your time to check out.
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Clear Day dbl.shotgun
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
    Clear day dbl shotgun
  • sponger
    sponger Posts: 325
    edited July 2013
    Lately I've been listening to an SACD in 5.1 on my S790. I am aware of the fact that an Oppo or the like would provide a more enriching experience, but for now I have no qualms about this player playing the one SACD that I own.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • obieone
    obieone Posts: 5,077
    edited July 2013
    A better CDP is a catch-22. A better cdp will make a well recorded cd sound better, while making a badly recorded cd sound worse.
    And don't be fooled by the term "Re-mastered". I've plenty of those cd's sitting on the shelf, that weren't even worthy of ripping as a .wav file:rolleyes:
  • ipsullivan
    edited July 2013
    ratster wrote: »
    Can't seem to find it, any chance you could post the link?
    Thanks.
  • PolkieMan
    edited July 2013
    There is nothing wrong with a 790 in fact Sony over Hdmi is pretty good IMHO. IF you want to play only SACD
    http://www.avsforum.com/t/1427207/best-and-cheapest-sacd-player
    sponger wrote: »
  • Tornado Red
    Tornado Red Posts: 939
    edited July 2013
    PolkieMan wrote: »
    Agreed. I have an Oppo 103 and love it, but the Sony 790 is a great machine for SACD/BD play at half the price of the Oppo.
  • sponger
    sponger Posts: 325
    edited July 2013
    Like the song goes..."My fellow Polkies all have Oppos. I must make amends."
    I do appreciate the positive feedback on the S790. It's the blu ray player that could. I do wish it had glowing buttons, but other than that I have no complaints. Nice to know that I'm not missing out.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • ipsullivan
    edited July 2013
    I have the opportunity to buy a Sony DVP S9000ES for $150. I did some research and its seems to be a great player. Any thoughts on it? Anyone have or used one before?
    billbillw Posts: 7,532
    edited July 2013
    ipsullivan wrote: »
    The S9000ES has a good reputation for sound and build quality, but the optical pickups go bad and are expensive to replace, and (worst of all), they are known to have difficulty playing CD-R/RW. I'd stay away from it if you like to burn music.
    Some of the older CD/SACD only (not DVD) Sonys are very good sounding and have no issues playing CD-R/RW. I have a SCD-C333ES that I've had for about 7 years and it has never had an issue with a CD-R. Very nice sound as well. If you want to stick to single disc players, you may also consider some of the Pioneer Elite DVD/CD/SACD and/or the Denon equivalents. I've had the Denon 2900 and the 3930CI in my systems at one point. Both were nice units. In fact, the 3930 is right up there with some of the best players. It runs hot though and I was having over-heating problems due to lack of cabinet clearance. Eventually I settled on my Pioneer PD-D9. I LOVE it.
    However, reading the entire thread, I do believe your problem lies with source material, and not your player. Itunes is not a good source for audiophile reference material. If you stick with downloading, take the effort to find FLAC files of well mastered material (ie Steve Hoffman/DCC, MFSL, etc.) You have to be resourceful though since many of the best recordings are out of print. You can often find original (ie: CDs) of them on Ebay, but be prepared to pay dearly for those.
