RTi4 vs RTi6
RodneyWoodford
I have a chance to pick up a set of new RTi6's for $199. I an using RTi4 's right now for the surrounds. Would the upgrade be worth it. I 'M ussing RTi10 as fronts. Thanks for any advice.
Post edited by RodneyWoodford on
Just my opinion, but $199 seems a little high considering the RTi6s were going at Newegg for $130-$150 last summer. I paid $75 for a used pair last year off local CL.
It may be a little high in the US but I'm in Canada and it seemed like a good price here.
I don't see WHAT you would gain by having a SLIGHTLY larger driver with the same tweeter in the 6s if you are only going to use them as SURROUNDS!
Don't bother. Use the money for more important upgrades. I doubt you'll hear much of a difference because the surrounds are usually crossed over at 80hz and the Rti-4s can handle that range as well as the Rti-6s!
Not worth it in my humble opinion. Like cnh said, save the money for a more important upgrade.Onkyo Pr-sc 5509
Parasound 2250/Parasound 5125
SVS PB 12 Plus
Denon DBP-2012 Bluray
Polk RTI 8, CSI 3, 4 FXI 3
Sony 55" LCD
