What center goes with Monitor 35b that's 5" or less high?
randommac
randommac Posts: 9
edited July 2013 in Speakers
I bought my first Polks at the beginning of the year, the new Monitor 35b, and added Martin Logan 10" subwoofer off of Craigslist. I'd love to have a Polk center channel speaker for movies, but have a mere 5 1/4" clearance above and below my TV. What fits that would sound good with the 35s? The Monitor 15c should be a good match, but at 7" high, is a no go. (And at least for the foreseeable future, the entertainment center the TV sits stays. I'm married and intend to stay that way.)
Opinions, please!
Post edited by randommac on
  • boston1450
    boston1450 Posts: 7,758
    edited July 2013
    Welcome to Club Polk. Im no expert at center speakers but im sure someone will chime in..thats a tight squeeze. Welcome....
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • randommac
    randommac Posts: 9
    edited July 2013
    I see the TL1 would fit. Is it a better speaker than the RM8?
  • randommac
    randommac Posts: 9
    edited July 2013
    Update: I found a way to remove the offending entertainment center shelf without destroying it. That lets me set the TV down and allows about 9" headroom above the TV.
    Now the question is: Monitor 15c center to match the 35b fronts, or is there any reason to go with the CS1 series II? The 15c is on sale at Newegg and the CS1 is about the same price by Polk on eBay.
  • Geoff4rfc
    Geoff4rfc Posts: 2,805
    edited July 2013
    Good job. I'd go with the 25C. IMO, never skimp on the center channel.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • Geoff4rfc
    edited July 2013
    ZLTFUL wrote: »
    If the OP on the other hand, has plans to upgrade to the 75Ts someday, then we are back to the 25C being a better option.
    Absolutely.
    As far as I can tell, all the speakers from that series are timbre matched
  • randommac
    randommac Posts: 9
    edited July 2013
    ZLTFUL wrote: »
    And normally I agree with this sentiment but in this case, I would go with the 15C as the 35Bs utilize the same 5 1/4" drivers vs the 6 1/2" ones in the 25C making the 15C a closer timbre match.
    Would love to upgrade to the 75Ts, but it's highly unlikely. Smallish room dominated by a fireplace and woodstove that can't be rearranged. :)
    I'll go with the 15C. Thanks for all the help thinking this through.
  • Geoff4rfc
    edited July 2013
    ZLTFUL wrote: »
    The tweeters are the same. The 5 1/4" drivers are all the same. The 6 1/2" drivers are all the same.
    But the 6 1/2" driver speakers will dig a little deeper which is going to match better with the same driver sized center channel. Timbre is more than just a series match.
    I don't think so in this case, just because you're matching driver sizes, it should have no impact on timbre. I found this on Wikipedia;
    In music, timbre (/ˈt
  • Geoff4rfc
    edited July 2013
    Sorry ZLT, didn't mean anything personal with the link.
  • randommac
    randommac Posts: 9
    edited July 2013
    "Side note, the latest revision of the monitors is the same drivers as the series IIs. They are only different in cosmetics and driver layouts)."
    Does that mean the CS1 is comparable to the 15c? The CS2 to the 25c? And thus a match for my 35b fronts?
  • randommac
    randommac Posts: 9
    edited July 2013
    True, aesthetics are a driving factor in all this -- this the need to work around the constraints of the entertainment center that houses the AVR, the TV, etc.
    Thanks a ton for your input and putting up with newbie questions. Great forum!
  • Geoff4rfc
    edited July 2013
    I once got the chance to demo the CS1 and CS2 side by side. While the CS1 sounded really good, once the CS2 lit up, the CS1 now sounded strained and unable to keep up in comparison.
    Maybe it's just me, but I'd want the best CC in a series, then build around that.
    Now, I'm not trying to start any wars or anything, but I found this on the Polk website;
    "All Polk loudspeakers are timbre-matched within their series, designed with the same components throughout, to achieve seamless speaker-to-speaker blending effects in multi-channel systems."
    "FYI, the word “timbre” can be pronounced either as “tamber” or “timber,” and refers to the musical “color,” or tone quality, of a sound."
    So if a guy want's to match driver size, by all means, there's nothing wrong with that at all, according to Polk, it appears that it isn't necessary in order to achieve a timbre match.
    Rock out baby :cheesygrin:
