Sub cross over settings?
CinderLyon
I have a Onkyo tx-nr809 receiver I am trying to set up. I have read that I should set the frequency cross over on my sub all the way up and then calibrate with audyssey and let the receiver determine room corrected frequency response.
Is that correct?
(the things i do to get my count up to 100 hehe)
Is that correct?
Fronts: Polk RTiA9
Center: Polk CSiA4
Sides: Polk F/XiA6
Rears: Polk RtiA3
Sub:Polk DSWPRO 660wi
extras: 2x JBL Monitor 4206
AVR: Marantz Cinema 50
Amp: Hypex UcD400 Class D, 2 Channels
Power Conditioner: Belkin PureAV Home Theater Power Console pf60
Many different streamers, Heos, firestick, apple
Center: Polk CSiA4
Sides: Polk F/XiA6
Rears: Polk RtiA3
Post edited by CinderLyon on
by lfe connections i am assuming you mean the rca sub out connection or is it something different?Fronts: Polk RTiA9
Center: Polk CSiA4
Sides: Polk F/XiA6
Rears: Polk RtiA3
Many different streamers, Heos, firestick, apple -
Yes, by "LFE" was meant the sub out on the receiver which accepts an RCA plug. To clarify a point, subs don't have internal crossovers. The frequency control is a low-pass filter which rolls off the response of the sub above the frequency set, but has no effect on the speakers, even if they're wired through the sub.
i always wondered what the speaker connections are on the back of some subs. I take it they are just pass throughs. what does the freq knob on a sub do? work in connection with the lfe settings in the receiver? Or is it a separate band pass cut off. or is it meant for reciverss that do not have an LFE setting option?Fronts: Polk RTiA9
Center: Polk CSiA4
Sides: Polk F/XiA6
Rears: Polk RtiA3
Yes, in nearly all cases the speaker level outputs on a sub are simply a straight-through connection which is the same as if the speakers were wired directly from the receiver terminals. A very few subs have a separate high-pass filter on the speaker level outputs which roll off the connected speakers below a fixed frequency of 100Hz or so. Even on these the sub's frequency control has nothing to do with the speakers. It rolls off the sub to "blend" with the speakers when used with a receiver which has no internal crossover which affects both the sub and the speakers. When the receiver is doing a crossover, the sub's low-pass filter should be by-passed by using its "LFE" input(if available)or setting it at its highest frequency so it won't interfere in the frequency range where the receiver is doing the crossover.
