Recommendations for a 8" Sub for Music.
Irrenhaus
Irrenhaus Posts: 1,098
edited June 2013 in Speakers
Hi all
Looking for recommendations for a 8" sub. This will be for music only the room is not that big I say 13X13 I will use for now a Pio Elite VSX-30 and the LS70 the source the Onkyo C-S5VL. I have now a cheapo Sony 8" sub. Budget is about $700.00 can go to $800.00 and also planning for separates in the future. I just lost a deal today of a GTP-500 and GFA-555 for $250.00 both damm the long company meeting...:sad:
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
Post edited by Irrenhaus on
  • Irrenhaus
    edited June 2013
    Irrenhaus wrote: »
    Hi all
    Cheers
    Looking at the use market found this ones:"
    http://www.bluemoonav.com/pre-owned.html
    Like the Rel Storm have done bussiness before with that store and like it.
    edited June 2013
    This is one place where a Polk sub (MicroPro 1000) really shines. This is one very nice 8". And it's available at almost half price, refurbed from Polk!
    http://www.ebay.com/itm/DSWmicroPRO-1000-BLACK-8-Powered-Subwoofer-Polk-Audio-/230976781504?pt=Speakers_Subwoofers&hash=item35c749fcc0
    cnh
  • Irrenhaus
    edited June 2013
    cnh wrote: »
    cnh
    That looks nice.
  • zingo
    zingo Posts: 11,258
    edited June 2013
    Can't go wrong with a sealed SVS subwoofer!
  • Irrenhaus
    edited June 2013
    Irrenhaus wrote: »
    Hi all
    Cheers
    Any opinions on the PSW111 or the PSW Pro440Wi for music.
  • rpf65
    rpf65 Posts: 2,127
    edited June 2013
    The 440 isn't bad for music, but is not very good for HT. I would probably advise you to look at SVS sb-1000 before you make a decision. It may be a 10 inch sub, but it has a small cabinet. May be a little better choice than either of the Polk subs you mentioned.
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited June 2013
    I have a Micropro 1000 in my 2 channel and a 3000 in my ht. Both do very well with music, and the 3000 is perfect for music and ht.
    New egg has 1000's new for $899
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882290129
    Garage | Polk Monitor 5B's
  • WLDock
    WLDock Posts: 3,073
    edited June 2013
    Hard to ignore these in the musical 8" category:
    http://www.hsuresearch.com/products/stf-1.html
    http://www.outlawaudio.com/products/m8.html
    Great feedback and direct price.
  • specd_out
    specd_out Posts: 505
    edited June 2013
    I did not like the psw111 for music, very boomy IMO
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • deronb1
    deronb1 Posts: 5,021
    edited June 2013
    Def tech pro sub 800
  • Irrenhaus
    edited June 2013
    DSkip wrote: »
    I've seen the MP1K go for around $450-500 on NewEgg. At that price, its a helluva sub for any purpose. Honestly? I'd say you'd be better served by investing that dough into a solid integrated, hybrid or full tube. The 70's sing on tubes and will leave you not wanting a subwoofer anymore. I ran a vintage 20 WPC tube receiver on my 70's and the bass was actually overwhelming for my 14x12 room.
    Hey thanks for the idea I have plans for tubes also but not now. I do like the Primaluna Prologue Six and just find out that the Onkyo sacd has volume control via the remote.
    Cheers
  • Irrenhaus
    edited June 2013
    Damm this is one that I have been looking for. But too much work this week and too many out of town trips......
    http://sfbay.craigslist.org/sby/ele/3881656044.html
  • squeeb
    squeeb Posts: 426
    edited June 2013
    A good sub to support sub-bass and integrate seemless would be a REL. 8" currently on Amazon for $699. http://www.amazon.com/REL-Powered-Subwoofer-Gloss-Black/dp/B008H55MZ8/ref=sr_1_1?s=electronics&ie=UTF8&qid=1371742142&sr=1-1&keywords=rel+subwoofer
    If you can find a T3, it's the previous model that can be found for less.
    7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
    Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
    Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi
  • Mystery
    Mystery Posts: 2,546
    edited June 2013
    deronb1 wrote: »
    I have two of the older version Prosub 80 and they are small but they are very good.
    Used ones are insanely cheap nowadays. Less than a hundy.
  • Irrenhaus
    edited June 2013
    squeeb wrote: »
    Thanks for the info I have been looking at a REL Q108 MK2 $389.00 or REL Storm Subwoofer for $599.00 but have not had a chance to go and hear them out. They are a local audio place.
