NAS PC Help
  • PrazVT
    PrazVT Posts: 1,607
    edited June 2013
    It says videos as well if you read the description - but yah, worth taking a look.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2013
    I'll check it out, thanks for the info
  • Syndil
    Syndil Posts: 1,582
    edited June 2013
    Probably is FireFly, the same iTunes service running on ReadyNAS. It allows a shared library to appear in iTunes (running on a computer) but not is a standalone iTunes server.
    From http://forums.macrumors.com/showthread.php?t=1394082
    The "iTunes Server" installed on the Synology and many other brands of NAS is not what you want it to be. It will show up in iTunes as a "Shared Library", but it is not the same as having a computer running iTunes with Home Sharing - meaning that you can't use it to serve your library to an AppleTV for example. You still need a computer running iTunes to do home sharing; the NAS can't take the place of that always on device.
