NAS PC Help
It says videos as well if you read the description - but yah, worth taking a look.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
I'll check it out, thanks for the info
Probably is FireFly, the same iTunes service running on ReadyNAS. It allows a shared library to appear in iTunes (running on a computer) but not is a standalone iTunes server.
From http://forums.macrumors.com/showthread.php?t=1394082The "iTunes Server" installed on the Synology and many other brands of NAS is not what you want it to be. It will show up in iTunes as a "Shared Library", but it is not the same as having a computer running iTunes with Home Sharing - meaning that you can't use it to serve your library to an AppleTV for example. You still need a computer running iTunes to do home sharing; the NAS can't take the place of that always on device.
