Weber Genesis or These? doing my outdoor kitchen.
doggie750
eah....bought me Ceramic Egg grill and now I need a gas grill. Any ideas and opinions shared are most appreciated. ... Thanks Polks.
Please see these grills below:
$499
www.bbqislandinc.com/sole-4-burner-grill-on-a-cart.html
$799 the 1st two grill
http://www.bbqguys.com/category_name_Built-In-Gas-Grills_path_2177-16900-9988-2114_start_0_pagesize_24_numresults_158_sorting_pricelow.html?&ff4=37
We all know weber has good product and service but option one has a see through insulated hood thus retains heat and eliminate the urge of opening. Self cleaning technology can be also a + factor. And the marked down price is hard not to consider. Seen this in person.
The last 2 candidates are almost the same +/- price range with the Weber genesis. The built in look and Specs are ideal. The only issue is that I haven't seen them in person.
Please advise. Thank you.
$499
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
Weber. Service and warranty. I got new burners and stainless steel grills three years after I bought mine...for free.
And I would imagine you won't see much through that hood after a couple of uses......_________________________________________________
It's hard to beat a Weber. I will probably never buy another brand, they last forever, cook very well and you can always get parts.
Own and use regularly three different Weber grills. Other grill mfgs. try to compare or associate to Weber for a reason.
Really? that's good to hear, we've had ours for about 3 years and the grill is starting to fall appart -
Weber charcoal grills are great, no experience with their gas grills.
I bought this gas grill last year and love it.
http://www.lowes.com/pd_404324-82210-463241313_4294703259__?productId=3851993&Ns=p_product_qty_sales_dollar|1
I was a little iffy on the whole infra-red idea but IMO it is the way to go for gas grills.
I use my Weber 22" for smoking.Speakers: SDA-1C (most all the goodies)
Weber genesis owner here. 3 years has come and gone without a hitch. It is outside under cover 24/7, and gets used year round at least once a week. Coming from a cheapie grill that I used and replaced parts until it was literally falling apart, the weber is AWESOME! It gets hot (close to 600 if I want it) and it cooks very evenly. Make sure you get the one with the cast iron grates. The parts are just much higher quality than you get on other grills in the same price category. The other grills will have lots of little extras, but what does that matter if it doesn't heat evenly and falls apart due to cheap parts?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I've had a Weber Genesis since 2000. It's been going great for all this time. I finally replaced the burners this year as the originals were starting to wear between little holes for the gas in the burners causing uneven flames. It looks like it was just the metal giving out after all the hot/cold cycles of grilling and not due to rust.
The best thing about the Weber is that it has lasted so long and I can still get parts for that grill.
I recommend getting the stainless steel flavorizor bars and grates (but that's me). I had the ceramic and they rusted and wore out. I replaced them with stainless and never had an issue since.
My dad has used the cheap gas grills ($100-$200 range) and I'm sure he's had 4-5 grills over the same time frame as me. Not only that, but those cheaper grills never cooked as evenly as the my Weber.Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Yamaha RX-V3800 Receiver
Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable -
I have a weber genesis. I love my grill. The build quality is top notch. I was not looking to spend more then $300 when I was shopping, but after feeling the build quality of that grill I was sold. it not gonna rot out like charbroils do. This sucker will last.
I would recomend going to lowes and HD to take a look at the standalone grills. Nothing compares to the solid feel of a weberHT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator -
I bought my gas grill, which I usually refer to as the outside stove, about 3 years ago. Was looking at a Weber, because they make great products. Saw a 5 burner Brinkman at Home Depot for less than $150, so I bought that. I put a grill cover on it when not in use, and have had no issues with it.
I'll confess, I use it probably about 50 times a year or so, because I prefer my old fasion charcoal/wood smoker. Have had that guy for 12 years, and have replaced the grates 3 times. -
Weber
No doubt about it unless you want to go HIGH END -
I just bought the weber genesis natural gas and love it. No more running out of propane in the middle of cooking. Stay away from the stainless steel gills at Lowes, HD, Menards - they are lower cost but have a low grade of stainless steel with nickel in it so it ends up rusting which SS isn't supposed to do. I learned my lesson and went weber for quality, customer service, parts, long life, etc
I vote Weber. Three years ago I bought a Weber Summit for almost $2000. Expensive, yes, but I was tired of replacing $300 grills every 4 or 5 years. This one should last forever.McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
I bought a Vermont Castings a couple years ago and couldn't be happier. I only chose it over the Weber Summit because of price.
I've had my Weber for 17 years and it still works great. That's the only one I would buy.Home Theater
Two Channel
