Can you up AC outlet handling on receivers?
Mr. Sharpe
Mr. Sharpe Posts: 1,359
edited June 2013 in Electronics
We're talking about Switched AC outlets on the back of receivers and preamps. Most all the old vintage receivers and preamps will have up to 8 outlets totaling over 1000 watts or just a few that will handle 300 and 500 watts. My Onkyo's outlets only handle 120 which really isn't good for any power amp. I'm wondering if there's way to jack the power handling of these up, to say maybe 400 or 500 watts so I could hook a power amp of substantial size (bigger than 80 wpc) Or is there another forum they talk about that kind of mod?
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
Post edited by Mr. Sharpe on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2013
    Does the amp have a remote 12v turn on jack? If so could use that as the turn on, and plug amps in the wall outlet directly.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    EndersShadow Posts: 17,704
    edited June 2013
    Or just get one of those power strips with a 12v trigger or that has a riggers outlet.
    Plug your avr into the master plug and the amp into a slave.
  • BlueFox
    BlueFox Posts: 15,251
    edited June 2013
    I doubt if having outlets on a receiver is doing anything positive to the sound, and is probably having a negative effect. Personally, I would use a power conditioner for having extra outlets.
  • Mr. Sharpe
    edited June 2013
    Not all amplifiers have 12v triggers see, an Adcom gfa1 is what I was thinking, but even more recent adcom amps don't have them, this is just for two channel.
    I would love to get a power conditioner but it'd only be for three components.
    Can upping the power handling on the outlets be done?
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • lanchile
    lanchile Posts: 560
    edited June 2013
    Mr. Sharpe wrote: »
    Are you sure is 120 watts? or it is 120V?
    Make it simple...Make it better!
  • cstmar01
    cstmar01 Posts: 4,424
    edited June 2013
    I agree to get a power strip or do something else and not plug into an avr.
  • Mr. Sharpe
    edited June 2013
    lanchile wrote: »
    the outlets are rated for 1 amp at 120 volts. 120 watts for two outlets. that post was referring to 12volt triggers used for turning components on or off.
    I just thought I'd use the outlet, little easier seems like. that's just me though
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • skrol
    skrol Posts: 3,449
    edited June 2013
    I agree with what is said above. On the subject of upgrading the outlets, it probably is not practicle if doable. There is likely a relay in the circuit that has its current limitations and the wiring. You might be able to upgrade both but may have trouble finding a relay that is the right form factor. You may also need to upgrade the power cord. However, you would still be better off powering an amp from its own outlet as the added wiring and relay will add resistance to the circuit.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 51,751
    edited June 2013
    Never, ever plug an amp into an outlet on a receiver. In fact, never use them for anything.
  • Mr. Sharpe
    edited June 2013
    Most all the receivers I've seen usually have 16awg internal wiring.
    Dad has had his GFA 1A plugged in the back of the GFP 1 for 30+ years, the GFP has 400 watt switched outlets. If the outlet has a 400 watt max why can't I plug the amp into it? I get the GFA1 has an 800 watts max but I would never use that. Are you saying it's going to mess something up regardless or are you saying it would hurt the sound so don't do it?
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • PolkieMan
    PolkieMan Posts: 2,446
    edited June 2013
    I would think it is a good way to induce noise into either unit, noticeable, that's up to you. I wouldn't do it.:wink:
  • zingo
    zingo Posts: 11,258
    edited June 2013
    Upgrading current rating is a bad idea.
    tonyb Posts: 33,072
    edited June 2013
    More fine advice from the dark one.
    Those outlets on the back are not ment to power amps. More so additional cooling fans, low power consuming items not huge ampere draws.
    Do not plug an amp into a receiver's outlet, period.
  • Mr. Sharpe
    edited June 2013
    Okay, won't do it. I'll look into make another strip with a toggle switch or something.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Speedskater
    Speedskater Posts: 495
    edited June 2013
    Most of the older receivers only had two pin receptacle's. The receiver's internal wiring and power switch are only suitable for rather low powered components.
    Power outlet strips are available with a control receptacle, that senses when you turn your receiver on or off and controls all the other receptacles. Twenty some years ago, RadioShack made a very nice unit but keeping with tradition they discontinued it.
  • Mr. Sharpe
    edited June 2013
    word, i just recalled hooking that old Adcom to my Onkyo in that outlet and the hum was much louder so that idea is out the window.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • disneyjoe7
    edited June 2013
    I have no issue using the switch outlet for a small 12vdc transformer to control amps and such. Are you against this also?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Systems
    Systems Posts: 14,873
    edited June 2013
    disneyjoe7 wrote: »
    Yep, they are good for "Triggers".
    Testing
    Testing
    Testing
  • Mr. Sharpe
    edited June 2013
    Like I said, my dad has had his Adcom GFA1A plugged to the back of his GFP 1 for 30+ years and it sounded absolutely Amazing, I guess neither of us knew what we were missing lol the only thing I use the outlet on the back of my 3805 is a cooling fan.
    I was just curious about this cus' I guess I'm too lazy to lean down and turn the amp on, but I guess that's where putting your amp up high comes in:) Thanks for all the posts.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • PolkieMan
    edited June 2013
    You could get you a long stick :razz:
    Mr. Sharpe wrote: »
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited June 2013
    I asked this ages ago. Most of the poll taken then said do not plug your devices into your preamp's outlets. This except for a few was a universal anwser. Never use those outlets in the rear of your preamp.Most said if you had to then the exception to this rule never your power amplifier. For me it would have worked perfectly if I wanted to use the Harmony1 remote, because the Adcom 555 has no remote if I were to plug it into the switched outlet of my Onkyo P-301 pre and then turn that on w/ the Harmony 1 then all would be a wonderful thing.Now w/ the same problem of my tt needs to be manually turned off I could also use that procedure.Again, no one was kidding said not to do it and forget the Harmoney remote and turn it off and on asI'm doing it now.....
    edited June 2013
    Personally I use the trigger outlet on my Citation 11 for my turntable but again thats me. Other than that device everything else is controlled by my Harmony one.
  • Glen B
    Glen B Posts: 269
    edited June 2013
    Mr. Sharpe wrote: »
    Even if it did not hurt the sound, inrush current when the amp is first turned on (which can be several times the outlet maximum rating) can overtax a preamp or receiver's power switch and cause it to fail eventually. Your dad is probably just lucky that the GFA1 probably does not have much inrush current at turn on, and he has not been driving the amp to the point where it has been exceeding the outlet rating foir any lengthy periods.
  • PolkieMan
    edited June 2013
    When I had an older unit that had those it was used for the turntable and cassette deck or cd player
  • unc2701
    unc2701 Posts: 3,587
    edited June 2013
    pepster wrote: »
    Agreed- but make sure the wallwart you use isn't noisy. I've had more than one instance when it was causing noticeable interference.
    Backburner:Krell KAV-300i
  • skrol
    skrol Posts: 3,449
    edited June 2013
    Good point. You want to stay away from switching power supplies (ie. laptop power supplies) as the can be noisy. Simple transformer with full wave rectifier and caps would do nicely.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • leftwinger57
    edited June 2013
    I just happened to find my Onkyo P-301 pre owners manual,Showing a tt plugged into a unswitched outlet @ 16a w/200wats max. the other swithched outlets are shown @ total 5w with 60Owatts max.No warnings are given either way to plug or not to plug your source devices into the Onkyo. My Samson 9 outlet surge center looks like a Furman does it all for me right now.It it'self is plugged into the wall directly.So whether opinions have changed around here on plugging devices into your pre/amps I still do not.
    treitz3 Posts: 19,988
    edited June 2013
    I just happened to find my Onkyo P-301 pre owners manual,Showing a tt plugged into a unswitched outlet @ 16a w/200wats max. the other swithched outlets are shown @ total 5w with 60Owatts max. No warnings are given either way to plug or not to plug your source devices into the Onkyo.
    Hello, please note that the bold portion of your quote was done by me. Plugging things into an AVR or pre used to be the "thing". It's OK if you do not care about the sound and it is correct that little to no warnings are provided with these outlets. With that said, what they do not discuss is;
    How it affects the sound.
    How it effects the current draw of the AVR.
    How it drains the available power to the amplifier section of said AVR.
    Unless you do not care about the sound and you listen only at extreme lower levels then plugging things into the outlets will usually not affect anything. If you DO care about the quality of the sound and if you listen at normal listening levels to concert level listening levels, then as F1nut mentioned before, never ever plug anything into the available outlets on a receiver/AVR.
  • jon s
    jon s Posts: 905
    edited June 2013
    Dunno if you guys noticed... but most AVR manufacturers no longer have AC outlets on the rear panels anymore... I was told too many idiots were plugging in high current devices in them, frying the AVRs....
