Polk RC65i's mounting in external wall (Insulation Question)
FuzzeWuzze
FuzzeWuzze Posts: 1
So i did some research, but im paranoid so i wanted to double check.
I know nothing about insulation/etc...
It looks like i have Fiberglass insulation? I ripped out a small bit of it where my speaker was going to get it in. My question is should i cut all the insulation in the speaker mount area away? Im worried about the fiberglass potentially contacting some of the electronics on the backside of the speaker because its open and the insulation tends to expand out and will probably be resting across the entire backside of my Polk RC65i's
Heres some images, im worried both about the fiberglass being flammable from the heat the speaker electronics make, and im going to assume its not conductive so i dont need to worry about it shorting my speakers? All of the leads more or less look like they are protected except the ones on the big giant resistor/varistors.
215361
215362
215363
Post edited by FuzzeWuzze on
  • zane77
    zane77 Posts: 1,696
    edited May 2013
    Fiberglass is very fire resistant and is also an electrical insulator, I wouldn't worry about it myself
    Two Channel
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2013
    I placed insulation behind a RC65i speaker that didn't have insulation.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
