FS: Top of the line Boston Acoustics T1030 Speakers in black (Denver local)
Mystery
Any love for Boston Acoustics here? :redface:
These were top of the line in that series and have amazing sound.
I like them a lot specially for long term listening due to their smooth sound but need to pass them on due to limited space.
Also, I can't use them to their potential due to small room.
They are in excellent condition except one speaker is missing one terminal cap and connector plates.
I'm using speaker wire to connect bi-amp terminals and work fine or can get terminal cup with connector plate very cheap online, around $10 at parts-express.
Thank you
Too heavy to ship.
$325.
Specifications:
High performance 3-way, floorstanding loudspeaker
Bi-Wireable!! A feature only found in high end speakers.
Frequency Response: 40-20,000 Hz
Impedence 8 Ohms
Dual 8" Copolymer bass drivers offer extended excursion
1" CFT soft dome tweeter
6.5" Copolymer Midrange
Tight, point-source driver alignment for precise imaging and wider dispersion
MagnaGuard® magnetic shielding prevents video interference
Heavily braced cabinets eliminate unwanted resonance
Reference-quality Boston Sound™
Recommended Amplifier Power: 15-150 Watts
Dimensions: 42.1/2" H x 10.1/4" W x 12.1/8" D
Weight: 65 lbs each
Color: Black Ash
Thank you
Too heavy to ship.
$325.
Specifications:
Impedence 8 Ohms
Weight: 65 lbs each
Color: Black Ash
Post edited by Mystery on
I've heard those and they're pretty nice. Would make a good front pair in a HT system. If I'm not mistaken that tweeter is NOT that different from what is in my A100s. The woofers also look a bit similar since I have A100 Series III (and the 10" woofer is a polycone).
GLWTS!
These are SOLD locally.
