Are my fronts too far apart from one another?
Seating distance is about 10 feet and so are the distances from one left speaker to the right speaker
Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
Surrounds- RTI 6 and Rear Surrounds- TS 15.
TV-Panasonic P55ST50
SUB-SVS PB10-NSD and PSW505
Receiver- Yamaha Aventage RX-A2000
Center- CSI5,
Post edited by oleon621 on
They are not too far apart, that big red border against the grey wall was the same color scheme of my bedroom in the 80's. I also had matching grey black and red drapes and bed spread
Thanks for the input. Just wanted to make sure they weren't too far apart. I actually got the paint scheme from some magazine. Maybe the 80's are back
I really like it. Should I have the RTI's close to the wall? They're about a foot away from the wall and that's probably the most I can do. Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
Receiver- Yamaha Aventage RX-A2000 -
Try toeing them in more and see if they sound better to you or not."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I'll give that a go. Should I run my YPAO system again after the toe in?Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
Yes, you will want to re-run it after any changesHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Don't look too far apart to me. Toe in would be my suggestion as well.
What type of stand is your center elevated on? I like that!Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Elemental Designs A2-300 Subwoofer
Panamax M4300-PM Power Conditioner
Working on updating my set up :rolleyes: -
Haven't tired the toe in yet because the whole family is home but will do as soon as the house is empty. As far as the stand, it's actually off a Samsung tv. Tv is mounted in the living room so I just used it as a stand. I thought it looked good too, thanks @poolgod69Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
haha good idea! I've done the same with my Pany Plasma TV Stand for my LSIM center speaker! Added the sticky rubber feet to the stand so I don't damage the speaker and its holding strong up on top of my 82" DLP on a shelf.
Also the speakers look fine. Just make sure that the tweeter is ear level with the seating position and with the toe in you want the speakers pointed directly at you if your seating position is center of the tv. So you want a Triangle shape between the speakers and the seating position.
I wish I could push my front speakers out further then they are as there right next to the screen on both sides. I've read ideally you want like atleast 3 feet of space between the center speaker and the fronts for good sound seperation.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
Ok guys so I did the toe in and I feel that the sound stage is directed more at me. Of course I sit in the sweet spot but now the sound just meshes well together in the center. ThanksFront- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
mine are just a far apart. I prefer it for HT. For music they should be closer together but its not a huge deal. You may want to get a wider tv stand. This way the speakers wont look so far outHT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator -
Depends on what you use them for, on the whole I don't think 10' is too far it's just the farther apart you go the smaller or farther out the musical sweet spot imo. Toe in helps though. I'd just play around with it til' you find the distance that gives you the sound you prefer. If you're mostly using for HT though then probably not as big a deal. Playing with speaker placement can have a bigger effect than some think so I would advise experimenting.
