Wood polish for UV protection for my LSiM speakers
eclypse
eclypse Posts: 595
edited May 2013 in Speakers
Wondering what I can use to protect my new LSiM speakers from sun light?
I had my Rti70s in front of the front window for the last 5 years and the right one is seriously faded and that's the one that was in direct sun light and the left side was not and looks just fine.Not wanting to have this happen again so thought theres gota be some wood product I can put on the speakers to protect it.
I have some howard Feed-N-Wax wood polish & conditioner Beeswax & Orange Oil that I thought I could use but it don't say anything about UV protection.
I was just gona leave it alone but I read the manual for the speakers and it says I can use a wood polish on it if wanted.
Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family! :)
Post edited by eclypse on
  • zane77
    zane77 Posts: 1,696
    edited May 2013
    You can get a UV protective film tat you can put on the window to protect the speaker, Google it I can't remember the name.
    Two Channel
  • eclypse
    eclypse Posts: 595
    edited May 2013
    Thanks for the suggestion.. sounds like too much trouble to use the protective film on the windows.
    Did a search online and found this..
    http://www.amazon.com/Howard-SWAX16-SunShield-Furniture-Protection/dp/B001EXZY8K/ref=sr_1_4?ie=UTF8&qid=1368035210&sr=8-4&keywords=howards+wax
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
    F1nut Posts: 51,763
    edited May 2013
    There isn't anything made that you can apply to your speakers that will prevent or even **** UV damage. There are a few things you can do such as keeping the curtain closed during the day and/or have UV blocking film applied to your windows. You could also cover the speaker during the day. There are companies that will make custom fitted covers for said purpose.
    One other thing, throw that polish in the trash can. If you absolutely need a polishing product for dusting purposes, use Guardsman. Otherwise, all you need is a damp cloth to remove dust.
    F1nut Posts: 51,763
    edited May 2013
    That product is made for items without a clear coat finish, which rules out your speakers. One would get the same results on outdoor furniture using any product containing wax. The claimed UV protection is a joke.
  • eclypse
    eclypse Posts: 595
    edited May 2013
    Ok thanks..
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • eclypse
    eclypse Posts: 595
    edited May 2013
    Guardsman Ultimate Dusting Cloth looks pretty good. I'll have to order up a 12 pack from amazon shortly.
    I guess the only option is to look into the uv protective window film as the window is always open during the day. Wifes wants it open.. if it wasn't such a big deal i'd throw the tv in front of it like I had it for 5 years when we first moved in but she wants the window hehe.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
    F1nut Posts: 51,763
    edited May 2013
    When looking into UV film, some are better than others and even then the ideal solution would be to block the sun completely. Any chance your wife would let you put a cover on the speaker?
  • eclypse
    eclypse Posts: 595
    edited May 2013
    I'll ask her about it when I see her on her lunch break.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • B Run
    B Run Posts: 1,888
    edited May 2013
    I'd be very careful about putting UV film on your windows. At least here in Texas where it gets 100+ all summer, if you tint the inside of a double pane window it greatly decreases the life of the rubber gasket inside the window, causing it to "fog" and lose visibility. It might be different up north so ymmv but just thought i'd throw that out there.
  • jbooker82
    jbooker82 Posts: 1,627
    edited May 2013
    Could the damage to your RTi70 been caused by vinyl wood grain? I could see vinyl degrading a lot faster than real wood.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    F1nut Posts: 51,763
    edited May 2013
    The color (dye or stain) applied to the wood or added in the finish will fade more quickly than vinyl. One can add a UV inhibitor to the clear coat, but it's not all that effective.
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2013
    Jess is dead-on. NOTHING "spray-on" will stop the sun from fading most anything. Take it from a Southern Arizonan. We had curatins fade even on the shadey side of the house, just from indirect sunlight!
  • codyc1ark
    codyc1ark Posts: 2,537
    edited May 2013
    I would just drape a towel over it when not in use. Everybody loves a towel... :razz:
  • rpf65
    rpf65 Posts: 2,127
    edited May 2013
    I say compromise. Board upthe window, paint the wall like an outdoor scene, maybe with a little blue bird sitting on a tree branch. Paint a window to frame it all in. Window is there, and no reason to worry about uv damage. If your wife goes for that one, you're welcome.:biggrin:
  • eclypse
    eclypse Posts: 595
    edited May 2013
    Mentioned the speaker cover to the wife and she didn't like the idea as in "We don't have the money to buy custom made covers". So whatever.
    How much would a pair cost for the 705s?
    Geese.. no idea this was going to be this big of a deal.
    I don't see how a towel could stay on the speaker as the top and back are so curved. I'd have to have some kind of paper weight on top to hold it from falling heh.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • eclypse
    eclypse Posts: 595
    edited May 2013
    The sun really only beams the front window till like noon but theres still sunlight coming on all day threw the window.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
    F1nut Posts: 51,763
    edited May 2013
    C'mon man, use your head......a blanket, a bathrobe, etc.
  • specd_out
    specd_out Posts: 505
    edited May 2013
    Listen to this guy, he know a lot about wood. :)
    He helped me out a ton when I refinished my speakers
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • eclypse
    eclypse Posts: 595
    edited May 2013
    I've spent too much money to look at these sexy speakers then to cover them up with a towel/bathrobe ext.. I'd rather just forget about it and if they look like **** in a year or so (hopefully move out sooner to a new house) i'll worry about it then.. strip them and restain.. of course not without a ton of expert advice or help before I take such a task on.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • sk88
    sk88 Posts: 159
    edited May 2013
    Would 303 Aerospace Protectant work? I use it for the leather in my car and a lot of people use it on anything outdoors. UV protectant doesn't last forever so you'd have to reapply it according to instructions. If you don't mind the trouble every 2 months or so, it will protect the rubber surrounds for sure.
    I am not associated with this product company in any way, but below is the production information from their website:
    303 is THE LEADER in UV Screening Technology. 303 Aerospace Protectant really is like "SPF 40 Sunscreen ... For Your Stuff." Regular use gives 100% Prevention of UV caused slow-fade with regular use. No other "protectant" beautifies as intensely, protects as powerfully or lasts as long.
    The World's Most Manufacturer-Recommended Product:
    Because of its enduring cosmetic properties, the resistance of 303-treated surfaces to dust, soiling, and staining, its water repellency and unparalleled protective characteristics, manufacturers worldwide recommend 303 Aerospace Protectant.
    303 Aerospace Protectant keeps UV-sensitive materials "like new" year after year.
    Use on Rubber: Tires, neoprene, latex, door and trunk seals, weather-stripping, EPDM rubber roofs, CV boots, waders, wet suits. Vinyl: Convertible tops (and the clear vinyl windows), isinglass, marine seating, tonneau covers, car bras, covers, spa covers, pool covers. Inflatable boats: Hypalon, PVC and urethane blends. Gelcoat fiberglass: Boats, RV's, snowmobiles, jet ski's.Plastics, acrylics, polycarbonates: Lexan® and acrylic panels, windows, , windshields, covers. Carbon-fiber/resin composites: Fishing rods, "nude" bike frames. Finished leather: Upholstery, motorcycle leather, trim, tack, fine apparel. Pool & Patio: Plastic furniture (not fabric), pool inflatables, slides, covers. Sailcloth: Dacron® and monofilm.
    • Online - Focal Solo6 BE, Polk PSW10, Focusrite Saffire Pro 24 DSP, Lenovo x220t
    • Music/HT - Lsi25, Lsi9 (Vr3), Lsi7, LsiC, Pioneer SC-68 & BDP-62FD, PS3
    F1nut Posts: 51,763
    edited May 2013
    It doesn't appear that product is recommended for clear coats such as lacquer found on most household furniture, so I would not use it on speakers, etc. without contacting the company first.
  • eclypse
    eclypse Posts: 595
    edited May 2013
    Thanks Sk88!
    Just shot off an email to ask them about it.
    Will let everyone know if it is safe to use.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
    F1nut Posts: 51,763
    edited May 2013
    Just saw this, ""nude" bike frames". That means no painted or lacquered finishes.
  • eclypse
    eclypse Posts: 595
    edited May 2013
    Heres the response I just got from them in email..
    Thank you for contacting Gold Eagle Co. 303® Aerospace Protectant is excellent for protecting finished wood (such as lacquer) and even teak. However, be advised that 303AP beautifying properties may change the look a bit (some might like it) because of the protective UV shield. If you would like, I can send you some information along with a sample for you to try. Simply respond with your mailing address and I will get this out to you right away.
    Best regards,
    Conrad Manzano
    Consumer Specialist
    (800) 367-3245
    marketing@goldeagle.com
    Gold Eagle Company
    Protecting, Preserving, & Performing Since 1932.
    I think i'll try a sample on a older Rti speaker and see what happends first.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • eclypse
    eclypse Posts: 595
    edited May 2013
    Heres another response I got..
    Thank you for your reply. I sent a sample of 303® Patio Furniture Protectant (same as 303® Aerospace protectant) along with a brochure for you to review. Please let me know of any questions or comments you may have.
    ? I guess they are sending me something else.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2013
    and keep in mind the finish on your RTi speaker is nothing like that on the LSiM
  • AsSiMiLaTeD
    edited May 2013
    Do what you want dude, but you've been warned...
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited May 2013
    I have the same problem only that it's the fabric that would fade. My DCM TF 350s were refoamed and resocked to their original dark brown color. Some of the sets on E-Bay are unbelievably faded. When I'm not home I cover them w/ a large towel. If I have to play tunes I go the other speakers that are not affected by the sun at that time.
  • Thorton
    Thorton Posts: 1,324
    edited May 2013
    Before you leave for work, close the blinds or drapes. When you get home, open them up.
    Unless you contact Polk, we don't know if the speakers are applied using a lacquer or polyurethane (chemical reacting) clear coat. The second is usually more chemical resistant. So you should be cautious or not use any type of cleaners or protectants unless the speaker manufacturer recommends it and the brand. Also since the speakers are designed for interior use, we do not know how good the UV protection is on the speakers themselves. They may last quite a long time before you notice a difference. Designing a clear coat with excellent UV protection is easy but can be very costly and in most cases would not be used on a product designed for inside the house. Also, sooner or later, the dyes in the stain (used for color) are not durable and will be affected by the sun. The stain, in most cases, is the weak link.
    I checked the MSDS on the 303 Aerospace Protectant. It is not stating anything that would probably hurt the finish. That does not imply that it couldn't. Some chemicals on MSDS may not need to be reported that could hurt the finish. However, is does state it is a milky product with a pH. They are probably using a cheap emulsion with a couple of drops of light stabilizer. This may produce a slight hazy effect to the speaker when applied on the surface. These type of products usually only give you minimal improvement (if any) and need to keep being applied. I'd stick with closing the blinds.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • WLDock
    WLDock Posts: 3,073
    edited May 2013
    I'm sure if you search around you could find a local home or auto upholstery shop, person, seamstress, etc. to sew up a couple of rectangular covers for not too much money. There are a ton of fabric choices that you can get local or on the net...could even find something that matches the decor of the room that the wife is happy with....maybe Microsuede...as low as $6/a yard:
    http://www.onlinefabricstore.net/search.htm?Ntk=primary&Ntt=microsuede&Nty=1&D=microsuede&Ntx=mode+matchall&Dx=mode+matchall&Sort=p_priceDown&s_kwcid=TC|1027047|microsuede%20fabric||S|b|24123150133&gclid=CPX1__mXmrcCFfFDMgodZSsAvg
