Subwoofer Advice Requested
bgsmith
bgsmith Posts: 8
edited May 2013 in Speakers
I have Polk RTi A5 front speakers with a DSW 440 sub. The sound is nice but sometimes i feel the bass is a little thin. I am not looking for wall shaking, just more presence. At first, I thought about getting a DSW 660 as that is one of the 3 recommended subs on the Polk web site. But I am also wondering if it would be better to get a second 440 instead?
Any thoughts?
Thank you
Brad
Post edited by bgsmith on
  • jbooker82
    jbooker82 Posts: 1,627
    edited May 2013
    You could go with a second 440 but it won't play lower. Would it be possible to use a 440 with a 660? Set the 440 up do do the mid bass and the 660 to handle the low stuff.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • B Run
    B Run Posts: 1,888
    edited May 2013
    What's your max budget? There's several options available that can give you the bass you're looking for.
  • be83663
    be83663 Posts: 192
    edited May 2013
    It is all about the diameter/size and how much of the air in the room is moved by the subwoofer.
    Get 15" Velodyne EQ-Max 15 Inch Subwoofer or two, after returning your current DSW 440 sub, man.
    It will do your system Good!
    A very friendly advise.
  • rpf65
    rpf65 Posts: 2,127
    edited May 2013
    Running the same combo here. After a whole lot of searching, decided on SVS PB-12 NSD. May want to give it a look.
  • Irrenhaus
    Irrenhaus Posts: 1,102
    edited May 2013
    Well I have an JBL L8400P is a 12" and does a great job in music with my Linn's. I am in the serach of a second at a good price for HT to use with the RTi12s.
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • bgsmith
    bgsmith Posts: 8
    edited May 2013
    Thank you. My max budget is about $1000.
    Brad
  • B Run
    B Run Posts: 1,888
    edited May 2013
    I'd personally check out the HSU vtf-15 for one of the best subs under $1k. Epik makes good stuff too but have been sold out. I'd take HSU over SVS unless you go up to the PB12+ which is more than your budget.
    http://www.hsuresearch.com/products/vtf-15h.html
  • codyc1ark
    codyc1ark Posts: 2,538
    edited May 2013
    B Run wrote: »
    Nice advice here, we all need to remember that Epik is going the ways of eD... Or at least it seems that way.
  • B Run
    B Run Posts: 1,888
    edited May 2013
    codyc1ark wrote: »
    Yeah learned my lesson there, still happy as hell with my ED sub and would have recommended it in a heartbeat otherwise. It's a shame.
  • ken brydson
    ken brydson Posts: 9,003
    edited May 2013
  • rooftop59
    rooftop59 Posts: 8,121
    edited May 2013
    All I can say is with that budget do NOT buy a polk sub. They make great speakers, but the subs still just can't compete with the ID boys as far as bang for the buck goes.
    I love my HSU and second that recommendation. I would buy this http://www.hsuresearch.com/products/vtf-2mk4.html and save the rest of the cash for something else. It will DESTROY what you have now, but is still very tight, controlled, and musical.
    Game Room 5.1.4:
    Bedroom 2.1
  • Poolgod69
    Poolgod69 Posts: 184
    edited May 2013
    I would insure your sub placement is optimal. Is your sub between your speakers, to the left or right of them up or in a corner? Move them around a bit and see if any differences arise. If you place the sub in a corner try having it close to the wall then gradually move it out a bit each time.
    Also, play with the hertz setting with different types of movies and music. Consider a setting it between 50-80hz vs moving to 30 or upto to 125/150/180 ect..
    This is my limited knowledge suggestion.... So take it for what it is.... lol.
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
    Elemental Designs A2-300 Subwoofer
    Panamax M4300-PM Power Conditioner
    Working on updating my set up :rolleyes:
  • WLDock
    WLDock Posts: 3,073
    edited May 2013
    Also, don't forget about craigslist. Too bad you are not closer to Seattle, there seems to be a lot of gear for sale in that area. Several HSU, SVS, Rhythmik subs on there.
    http://seattle.craigslist.org/search/ela?zoomToPosting=&query=SVS&srchType=A&minAsk=&maxAsk=
    http://seattle.craigslist.org/search/ela?zoomToPosting=&query=HSU&srchType=A&minAsk=&maxAsk=
  • ken brydson
    edited May 2013
    WLDock wrote: »
    Couple of those are Polkies...
  • WLDock
    WLDock Posts: 3,073
    edited May 2013
    Not a suprise...Polkies are everywhere!
  • Poolgod69
    edited May 2013
    WLDock- Since we are both in Indiana how about a road trip to Seattle. Seems like athat is the place to go to obtain our subwoofer needs.....lol
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
  • codyc1ark
    edited May 2013
    You COULD do this and have nearly enough money left over to buy an SMS-1....
    http://www.polkaudio.com/forums/showthread.php?143588-Dayton-Audio-RSS460HO-4-18-quot-Reference-HO-Subwoofer
    Oh and by the way, I've spent some time in Carmel and liked what I saw.
  • Poolgod69
    edited May 2013
    codyc1ark wrote: »
    Def would like to get into a DIY project but I am just unsure which on since the are so many!!!
    Carmel is a great place to live!!
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
  • bgsmith
    bgsmith Posts: 8
    edited May 2013
    Thanks to all for the discussion and recommendations. Lots of interesting choices and options.
    Brad
  • Polkfan1017
    Polkfan1017 Posts: 1
    edited May 2013
    Check out the PSA XV-15. $799. I just bought one for my media room and it is a phenomenal sub. 15" driver. I couldn't be happier with it. http://www.powersoundaudio.com/products/xv15
  • chiptouz
    chiptouz Posts: 152
    edited May 2013
    B Run wrote: »
    +1. I own the HSU VTF3-MK4 and love it. HSU makes good products and the VTF-15 is awesome.
    Sharp LC-80uq17u
    Denon 4520ci Receiver
    OPPO BDP-203 Blu-Ray Disc Player
    Monster HTS 3600
    Polk RTi-a7 (fronts)
    Polk CSi-a6 (Center)
    Polk TC-60i (Rear & Surround Rear)
    HSU Research VTF3-MK4 (Sub)
    Logitech Harmony elite (Remote)
  • Jhayman
    Jhayman Posts: 1,548
    edited May 2013
    Wasn't Clint Eastwood the Mayor of Carmel if my memory serves me correct.
    You guys in the US certainly like your elected officials to have acting experience, lol
    Poolgod69 wrote: »
  • Poolgod69
    edited May 2013
    He was the Mayor of Carmel, California. That would have been pretty cool... That would have "Made My Day"
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
  • B Run
    B Run Posts: 1,888
    edited May 2013
    I'd like to hear one of those as well, they look like a great bang for the buck.
