Need advice on new Polk's
Bob1947
Bob1947 Posts: 39
edited May 2013 in Speakers
I want to upgrade my Monitor 60's which are my fronts. I am looking at either the LSIm 705's or RTi A9's. Can anyone comment on which gives the best performance. I listen to a lot of jazz, blues and classical. I am wondering which pair would compliment my rear LSI 9's. My system is in my basement (carpeted) which is about 15' by 25'. I wish I knew more regarding the technical aspects, but my audiophile learning curve is steep. For the amount money involved in either one of these speakers I want to make the best decision. I wish I could find somewhere I could have a demonstration, but I am unsure of where Polk's are sold in my area. Certainly want to avoid the box stores. Thanks in advance.
Regards, Bob
Samsung PN51E6500 Plasma
Marantz UD 7006 7.1 Blue Ray/CD/DVD Player
Marantz SR 7007 HT Procesor
Polk LSiM 705 Fronts
Polk LSiM 706c Center
Polk LSiM 703 Rear
Klipsch RW12D Sub
Music Hall 5.1 SE TT
Post edited by Bob1947 on
  • [Deleted User]
    [Deleted User] Posts: 1,394
    edited May 2013
    Bob,
    I have approximately the same room size as you and have the LSIM 705's. given this room size, I would recommend powering them with am external amp. I found that using a receiver ( pioneer elite SC37 ) did not do the speakers any kind of justice.
    The 705's are not as forward or bright sounding as the RTIA's. The 705s are very balanced in sound, from top to bottom and would recommend it over the other choice for music. I also feel that your LSI 9s are very laid back in sound whereas the 705s are more lively. They will still pair together much better than then RTIA.
    If you could power the 705s with a tube amp, you will not regret it. It sounds very good.
    Halen
  • Bob1947
    Bob1947 Posts: 39
    edited May 2013
    Thanks for your comments. I was leaning toward the 705's, but since I already put out 1550 for the NAD it will be awhile before I look at tube amps, at least for now.
    Regards, Bob
    Polk LSiM 703 Rear
    Klipsch RW12D Sub
  • eclypse
    eclypse Posts: 595
    edited May 2013
    705s!
    Checkout Polks ebay store for cheaper prices.. could maybe get a better deal if you email them about it.
    http://stores.ebay.com/polkaudiodirect
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • custopper30
    custopper30 Posts: 252
    edited May 2013
    +1 for the 705s!!!!
    Receiver: Denon 1912
    Speakers:
    Fronts: Polk Audio Monitor 70s (x2)
    Rears: Polk Audio Monitor 50 (x2)
    Center: Polk Audio Monitor 70
    KLH Sub GFX-550
  • Bob1947
    Bob1947 Posts: 39
    edited May 2013
    Thanks for everyone's input, The 705's it is. I can get them for around 2400 on polk ebay. Should be a major improvement over the 60's. Next questions is whether to bi-amp or leave them be. Also need ideas of what would be a good speaker cable and whether or not to use pin or banana's. Audioquest is a great company, but pricey.
    Regards, Bob
    Polk LSiM 703 Rear
    Klipsch RW12D Sub
  • zingo
    zingo Posts: 11,258
    edited May 2013
    Don't bi-amp when you can use a single good amp with the LSis. Good choice with those speakers, and used speaker cables are a good value.
  • eclypse
    eclypse Posts: 595
    edited May 2013
    Yes totally forget about bi-amping. No point wont matter forgetaboutit.
    Get a 200 watt+ amp for them and some decent speaker wire.
    Lots of people like this option.. http://www.bluejeanscable.com/store/speaker/index.htm
    Buy either them already made for you or just buy the bulk cable and make them yourself.
    Bi-wire not needed either with the LSiM speakers.. but looks cool! haha.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • WLDock
    WLDock Posts: 3,073
    edited May 2013
    Sounds like a very nice upgrade in the works. Jazz combined with the 705's combined with some wine will complete the trilogy. Sounds like my type of fun.
  • sk88
    sk88 Posts: 159
    edited May 2013
    Pin plugs has less contact area than banana, so I'd say use banana. If someone was to trip the speaker cable, banana would just get pulled loose. With pin, it would take down the speaker or the amp since it's screwed on tightly. If you have to place the speaker or your amp against the back wall, although not recommended, pin can save you space as it goes in vertically vs. banana goes in horizontally. It's much easier to plug/unplug banana.
    • Online - Focal Solo6 BE, Polk PSW10, Focusrite Saffire Pro 24 DSP, Lenovo x220t
    • Music/HT - Lsi25, Lsi9 (Vr3), Lsi7, LsiC, Pioneer SC-68 & BDP-62FD, PS3
  • custopper30
    edited May 2013
    I like the banana a lot more. Just recently got them for my 70, and 50s and they make a big difference for plugging and playing
    Speakers:
    KLH Sub GFX-550
  • jbooker82
    jbooker82 Posts: 1,627
    edited May 2013
    You could always get a pair of single biwire speaker cables. On the reciever / amp end there is 1 set of bananna plugs. Then on the speaker end there is two pair. That way you can remove the jumper straps and not need to make a speaker wire jumper.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • jbooker82
    edited May 2013
    I use AudioQuest Type 8 single biwire cables with my RTi's.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    F1nut Posts: 51,674
    edited May 2013
    Bob, why and how are you using rear speakers in a 2 channel rig?
    That said, get the 705's and hook them up with MIT Shotgun series cables.
  • Dawgfish
    Dawgfish Posts: 2,554
    edited May 2013
    You definitely made the right choice with the 705s. Your NAD integrated is a very good unit and should have no problems powering the 705s and sounding good in the process. As the others have stated, don't worry about bi-amping them right now. Run them on the NAD and get a good feel for what they can do. Speaker cable upgrades will also make a very good and noticable improvment (as will IC upgrades). There are a lot of good choices out there. Congrats and enjoy!
  • Bob1947
    Bob1947 Posts: 39
    edited May 2013
    For no other reason than I already owned them so I thought just to connect them. I sometimes just run the fronts alone, sometimes both together, no specific reason. I am not into HT or surround sound. My NAD is a straight two channel amp and 95% of my listening is music. Hope that answers that question. Thanks for your comment. I already ordered terminated banana cables (5000ue) from Blue Jean. Perhaps someday I will research cables upgrades and find out more on whether it pays or not. Alot of opinion on this. For right now the 200 bucks for these speaker cables will work for me.
    Regards, Bob
    Polk LSiM 703 Rear
    Klipsch RW12D Sub
